Linkwitzlab Website down?
Old 11th February 2018, 07:13 PM   #11
Skylar88 is online now Skylar88  South Africa
Thanks for checking. I still can't access the site. DNS resolves, but I can't ping it.
Old 11th February 2018, 09:31 PM   #12
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
maybe the server doesn't respond to pings, I can access the site via browser, yet I can't ping it
Old 11th February 2018, 09:33 PM   #13
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
What if you try a free proxy server in between?
Old 11th February 2018, 10:17 PM   #14
ICG is offline ICG  Germany
ICG's Avatar
The site works for me too but I can't ping it either. I assume somewhere (likely in the datacenter of the site) pings and other services, protocols and maybe ports/portranges are simply blocked. That is often the case to prevent or fight a DDOS attack.
Not being able to reach the server while it's actually up is a different thing though. You can always use some net tools or pages to check if the sites are up or not. i.e. Domain Dossier
If it's up, then it's maybe a block in the DNS or IP. The former can be avoided by using a different DNS than the provider usually 'defaults'. There are a lot free DNS available, I prefer Google (8.8.8.8 and 8.8.4.4 - you have to change it in the router or in the connect string of the modem, maybe keep one of the providers DNS and one of the Google ones).
A proxy, like globalplayer suggested, works fine but with that you need a safe, trustworthy proxy and free ones which are, are rare. For just browsing without a login etc. most should be fine though.
For some pages there are mirrors which should provide the same content if they are synced regularily.
Apropos content: The newest post on the Linkwitz website is from the 20. december 2017 announcing his retirement and that he's stopping the sales.
I had a Dj Moo - I've seen that BS before!
Old 12th February 2018, 09:49 AM   #15
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Nope, last update is from January 28th
What's new at LINKWITZ LAB
AINOgradient speaker project
Old 12th February 2018, 04:02 PM   #16
That's too much trouble just to access one website. It used to work. I'll wait and see if it comes back later.
Thanks for all the suggestions.
Old 12th February 2018, 09:42 PM   #17
kevinkr's Avatar
Try the suggested DNS fix, it has worked for me in the past. My current ISP's DNS servers seem to work fine, but the previous one's didn't and I used Google's instead.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th February 2018, 06:20 AM   #18
I switched off WiFi and could then get to Linkwitzlab on my phone. So it must be DNS or ISP related. I'll try the Google DNS thing.
Thank you to everyone for suggesting fixes. I have actually given up, but that last post made me do the DNS/ISP check.
Old 13th February 2018, 01:15 PM   #19
kevinkr's Avatar
Good news! Using alternate DNS may fix the problem then. A complaint to your ISP about blocking legitimate IP addresses might also be in order. (I have done that successfully as well)
Linkwitzlab Website down?Hide this!Advertise here!
Linkwitzlab "Watson" gainphile Multi-Way 236 16th February 2016 03:40 AM
MiniDSP and LinkwitzLab gainphile miniDSP 17 30th January 2014 03:32 PM
Does anyone know the website? Hastur Subwoofers 2 16th March 2006 03:08 PM
linkwitzlab dipole sub hifidan Subwoofers 5 8th July 2004 02:48 PM
