Hypothetical Stepped Baffles
Old 17th June 2013, 05:10 PM   #11
badman is offline badman  United States
badman's Avatar
I'd want to minimize center/center spacing, via the rounded shape, and a rear-mounted tweeter (with the dome right up against the edge of the beveled shape). I wouldn't want to do this with the flat beveled piece, and the pointed arrangement doesn't allow quite as close a CTC spacing since the midwoofer frame will need to be further down. Because the distance from the midwoof panel edge to the tweeter will be widely varied (and "soft" because of the bevel) I think this would exhibit both better summation and minimal diffraction artifacts. Felt on the portion closest to the dome might not be a bad idea though, if it's right next to the dome.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 17th June 2013, 06:08 PM   #12
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
Badman,
I am in agreement with you that more thought should be given to decreasing the ctc distance between the two drivers. If you are going to rear mount the dome tweeter why not use part of the radius contour between the two devices as part of the slope leading into the dome tweeter and remove the steps as shown on boris81's cross sectional dtawings? Sometimes it is as simple as cutting a section of the front plate away so you can put the two devices closer together.
Old 17th June 2013, 06:50 PM   #13
jimbones is offline jimbones  United States
Default Looks familiar
Gee that looks eerily familiar to mine
Hypothetical Stepped BafflesHide this!Advertise here!
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 23 12th February 2013 02:23 AM
Hypothetical question on multiple Small woofers vs few larger woofers navin Multi-Way 38 7th June 2010 11:17 AM
Hypothetical volume control situation CigarBoxAudio Solid State 2 2nd August 2009 10:54 AM
Hypothetical question on patents Genomerics The Lounge 49 26th July 2006 09:44 PM
Weird amp testing hypothetical Geoff-AU Parts 1 19th November 2005 02:10 AM
