EPOS 14 Super Size
EPOS 14 Super Size
Old 18th June 2013, 02:26 AM   #31
gassit is offline gassit  Australia
Hi Pete,
That last suggestion is definitely worth trying; I'll give it a go this weekend.
Thanks.
Old 18th June 2013, 04:10 PM   #32
PB2 is offline PB2  United States
PB2's Avatar
3 to 6 mH is in the ball park.
Note that this design uses 10 mH with about a 9 ohm woofer:
http://www.diyaudio.com/forums/multi...rid-xover.html
Do you have some different inductors to try?
Old 18th June 2013, 07:41 PM   #33
system7 is offline system7  United Kingdom
system7's Avatar
Originally Posted by dumptruck View Post
Approximately, on some axis. I guess if you were to use response measurements and the inverse of the crossover phase shift to determine the phase tilt inherent to each driver, then use that phase and the driver response to determine the physical offsets relative to the measurement location, then maybe you could simulate a new crossover with phase tracking that is close to reality? I don't see how you could do that with the Stereophile measurements, though (averaged sum measurements).
Didn't understand a word of that really. Let's hope Christian Ponder gets simpler instructions from Leslie Frazier next year, because we surely have common ground in loving the VIKINGS. Skal!
My approach was a lot simpler. I outline it below in a visual form. 6" bass plus 1" tweeter is fairly standard stuff that works. The phase is not going to be a million miles away, though I'd dump the metal dome.
I really like PB2's suggestion of converting it to a 2.5 Way speaker. I'd guess you want to get near closed box on the Epos (Using a foam plug on the reflex) and add a 6" woofer and Zobel on a near 10mH coil, as with the B&W Matrix 3. You should then get some bass and spare the Epos from bass excursion. Wasn't there a Rogers subwoofer for the small but beautifully formed BBC LS3/5A along these lines?
Best Regards from Steve in Portsmouth, UK.
EPOS 14 Super SizeHide this!Advertise here!
Epos es14 Squiffy Swap Meet 2 9th December 2009 04:50 AM
Improvement on Epos's Holty Full Range 3 11th January 2007 06:35 PM
EPOS ES22 construction Pete Fleming Multi-Way 11 23rd February 2006 10:41 PM
