EPOS 14 Super Size
EPOS 14 Super Size
Old 16th June 2013, 02:20 AM   #21
dumptruck is offline dumptruck  United States
Seems a bit bold to claim you've improved the phase alignment of a speaker when you don't have phase measurements of the original...
Old 16th June 2013, 02:50 AM   #22
gassit is offline gassit  Australia
Okay...
I'm going to study all of the above during this coming week and then make a decision.
Old 16th June 2013, 07:48 AM   #23
fatmarley is offline fatmarley  England
Check out Partsexpress for sub building. Those guys are building subs all the time.
I'd personally go sealed with a box Q of between 0.5 and 0.7 (the nearer 0.5 the better).
Old 16th June 2013, 08:47 AM   #24
system7 is offline system7  United Kingdom
system7's Avatar
But we DO have a phase measurement of the original...it's IN PHASE at 3.2kHz crossover.
The rest is just TECHNIQUE, as they say. Nobel prize winner Dick Feynman, who developed the only theory of the electron that works known as QED, was a great friend of Lenny Susskind, as it happens. Two giants of physics, both having the rare ability to look at complex things in a simple way.
Richard Feynman on the Double Slit Paradox: Particle or Wave? - YouTube
Ah, back to subwoofers.
Best Regards from Steve in Portsmouth, UK.
Old 16th June 2013, 08:59 AM   #25
Rojoh is offline Rojoh  Norway
Rojoh's Avatar
Originally Posted by gassit View Post
Thanks everyone.
I knew that someone from the US would chime in once I mentioned sub-woofers.
Whew! I'll have no trouble building the subs but I'm not so sure about the electronics.
The subwoofer could be a simple 8" or 10" in a sealed enclosure. I think you're right regarding electronics.
There are two schools when it comes to subwoofer use and implementation:
1) Thoose who just want to add subfrequencys to the main speakers.
2) Thoose who want active crossover, filtering low bass away from main speakers.
I think 1) is most popular in UK. Perhaps because you have things like flat earth, source first and PRAT from the Naim/Linn community. Seems like REL are one of the only subwoofer manufacturer that's approved with their ability to low-pass the sub really low.
Personally I prefer the no. 2) approach - filtering the low frequencies out of the mains, and handing over the sub-duty to eksternal woofers. In order to acheive this, you'll need an active or passive line level crossover in the signal chain - usually between preamp and poweramp.
Both approaches have their own pros and cons.
Putting out fire with gasoline.
Old 16th June 2013, 11:04 AM   #26
Just about to visit Kip City now.
Those last two posts should provide plenty of nutritious fertiliser for tonight's field of dreams.
Old 17th June 2013, 05:45 PM   #27
Approximately, on some axis. I guess if you were to use response measurements and the inverse of the crossover phase shift to determine the phase tilt inherent to each driver, then use that phase and the driver response to determine the physical offsets relative to the measurement location, then maybe you could simulate a new crossover with phase tracking that is close to reality? I don't see how you could do that with the Stereophile measurements, though (averaged sum measurements).
Old 17th June 2013, 07:28 PM   #28
PB2 is offline PB2  United States
PB2's Avatar
My heart always sinks when I hear people mention Doppler distortion in loudspeakers...
There is NO SUCH THING!
We all know what ambulances sound like when they are approaching or departing, the tone changes, but this has nothing to do with linear systems.
The whole basis of the Fourier Transform is that the sine waves do not interact.
I WOULD buy an explanation that excessive bass takes a loudspeaker outside its linear area and causes INTERMODULATION between frequencies.
As for more bass from a two-way like the EPOS ES 14, well you really need a three way for a bigger room if you want it to go loud without distortion. That's the simple physics of it!
Doppler exists the question is if it is audible for a given situation. Note the
references from Klipsch and Linkwitz:
Doppler Distortion in loudspeakers
Old 17th June 2013, 07:35 PM   #29
PB2's Avatar
If you really want to build a tower enclosure, why not measure the T&S
parameters of the woofer and find one that is close. Perhaps something
like the Dayton Reference drivers. Then add the second woofer closer to
the floor with a large inductor in series to give it a bit more baffle step
compensation and to reduce the floor bounce null. Is it an 8 ohm system?
It will then be 4 ohm in the bass after the change, can your amp handle it?
Old 17th June 2013, 11:15 PM   #30
PB2's Avatar
Another thought, you could test this idea in mono by stacking your 2 speakers and driving the lower woofer (system) through an inductor, with a Zobel on it. Listen in mono and give it time (a few days) so that your ear-brain can re-adjust through FR adaptation.
This leads to the idea, if you like the above arrangement, to just make stand/boxes that are the same size as the originals tuned to the same frequency with a driver that is similar to the original. The divided enclosure avoids introducing new/different box modes.
You now have more driver excursion making it reasonable to shift the box tuning lower, say to 35 Hz or so if you prefer more extension.
EPOS 14 Super SizeHide this!Advertise here!
Epos es14 Squiffy Swap Meet 2 9th December 2009 04:50 AM
Improvement on Epos's Holty Full Range 3 11th January 2007 06:35 PM
EPOS ES22 construction Pete Fleming Multi-Way 11 23rd February 2006 10:41 PM
