Old 5th December 2003, 09:31 PM   #1
Tuukka is offline Tuukka  Finland
Tuukka's Avatar
Default tesla loudspeakers
i acquired a pair of old speakers from a friend of mine. i tried researching these speakers but could not find anything about them. hopefully someone here might know.
brand and model number are Tesla ARO-666. it's an 8" speaker with a blue frame and a black plastic cover over the magnet. very vintage: thin paper cone, accordion surround, no real dust cap, instead there is a small mesh. apparently they came out of an old record player.
i built a roughly 25liter sealed enclosure for them and they sound very detailed and full as they are just running fullrange with no eq or xo. impressive for a pair of speakers that sat hanging off a shelf, in a free-air baffle, in a dusty garage on a farm for at least a decade, with the sun constantly beating on their back through the window.
anyway, just wanted to see if anyone on the forum has heard of these drivers or even the brand.
Old 8th June 2004, 11:00 AM   #2
deiksac is offline deiksac  Czech Republic
Send a message via ICQ to deiksac
this is an obsolete model made by tesla (now tvm acoustics - www.tvm.cz) in 70s, i was trying to find something nore specific about it but their data is not very accurate
Old 8th June 2004, 11:03 AM   #3
could be some 5 watt, sensitivity somewhere near 86-87 dB
its successor was ARN (i think, am not sure) 6604(8) with some twenty watts, better magent but more or less same cone
Old 14th June 2004, 04:54 PM   #4
if you would like me to find something more specific about them, please ask
Old 6th July 2004, 03:15 PM   #5
Bose(o) is offline Bose(o)  Canada
I remembered this thread a while ago and after cracking open a pair of Toshibas that my friend had given me, I just had to post. I have the exact same speakers that you are using right now. I'm going to measure their T/S specs in about 30 minutes or so. If you want efficiency and such numbers, tell me how to measure them and I will.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 6th July 2004, 03:22 PM   #6
You can CALCULATE efficiency from the TSPs.
Charles
Old 6th July 2004, 03:30 PM   #7
oh yeah...that's right! My bad.
ERTW 4 life!
Old 6th July 2004, 05:45 PM   #8
Tesla ARO 666 T/S parameters:
Qts:0.81
Vas:17.3L
Fs:93Hz.
Re:7.7ohm
Le: ?
Xmax: ?
Qms: 4.79
Qes: 0.98
Pe: 5W (as per back of magnet)
Sd: 268.66cm^2
SPL: 74dB.@1W, 1m. (seems a little low.)
ERTW 4 life!
Old 31st July 2004, 06:45 AM   #9
frugal-phile(tm)
planet10's Avatar
It certainly does... i've had a number of these, and they were all closer to the 86-87 dB figure mentioned earlier.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st July 2004, 06:59 PM   #10
Planet10,
Where did you enlist your Tesla speakers for use? I was thinking of using the C-channel on my Sansui for the other sections of the basement and also making use of Open Baffles.
ERTW 4 life!
Tesla Fullrangers.... JandG Full Range 9 31st July 2008 05:23 AM
Tesla Guitar culture Instruments and Amps 8 18th March 2008 09:19 PM
Tesla cap value prerunnerv6 Multi-Way 2 10th February 2006 03:01 PM
JJ Tesla eeka chu Tubes / Valves 3 26th November 2004 08:10 AM
Is Tesla still going? Hesky Tubes / Valves 4 18th July 2004 11:42 AM
Page generated in 0.10618 seconds (76.24% PHP - 23.76% MySQL) with 11 queries
