Wavecor bookshelf
Wavecor bookshelf
Old 10th June 2013, 06:20 AM   #1
PeteMcK is offline PeteMcK
Default Wavecor bookshelf
I've put together a pair of bookshelf speakers using this driver:6.25" - 4 Ohm - Ferrite - WF160WA02
& a Matsuhita cone tweeter, which is all I had lying around. The box is ~ 16L tuned to 52Hz made from offcuts from a neighbour's shelving project.
Crossover - currently 1st order .56uH on the woofer, 5.8 uF & .68 ohms on the tweeter, but I may have to go higher order, the Fs of the tweeter is 2.5KHz, so I'm a bit close... . Balance is pretty good, but needs more listening, tweaking, beer etc...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 11th June 2013, 05:57 AM   #2
After searching through my parts stash, I found parts for 2nd order on the tweeter, which sounds good. I note that the woofers have jumped in price from $50 about a year ago when I bought these, to ~$80 now...... if you're in Aus, SB drivers are a much better deal
Wavecor bookshelfHide this!Advertise here!
Wavecor tweeters crazyhub Multi-Way 1 30th December 2012 12:57 PM
Wavecor 6.5" WF160WA02 PeteMcK Multi-Way 29 19th September 2012 06:22 AM
Wavecor TW030WA10 Karl vd Berg Multi-Way 3 17th July 2012 10:00 PM
Wavecor FR070WA01 fakeout Full Range 32 5th April 2012 11:14 PM
anybody experienced wavecor drivers? rhythmdiy Multi-Way 24 18th October 2007 02:25 PM
