Determining When Tweeters are in Phase - diyAudio
Old 9th June 2013, 10:43 PM   #1
gassit is offline gassit  Australia
Default Determining When Tweeters are in Phase
With some second-order crossovers, it's recommended to reverse the phase of the tweeters.
How can you tell when the tweeters are correctly phased?
Old 9th June 2013, 11:50 PM   #2
JonSnell Electronic's Avatar
If they are out of phase, one pushes as the other pulls, the sound in not natural.
There is no centre for the audio and it is very noticeable.
Old 10th June 2013, 12:16 AM   #3
oldmanaudio's Avatar
Default phase
If you have access to a acoustic measurement system all have to do is perform a frequency response test. Then switch the polarity of the tweeter and if the phase is correct a deep dip will be present. I use this technique for all types of crossovers. If you don't have a measurement system there is a few free programs that use computer sound cards. Speakerworkshop is one I like
Old 10th June 2013, 12:19 AM   #4
jcx is offline jcx  United States
if the XO design requires phase reversing a driver then there will be a pronounced dip in the acoustic output frequency response at the XO frequency if you get it wrong
most physically small condenser mics are fine for audio midband measurements - no calibration needed - you are looking for a deep notch on axis, at listening distance
best done where reflections can't interfere, speaker lying on back outdoors is simplest
Old 10th June 2013, 12:51 AM   #5
Default phase
Another free program is holm impulse HOLM Acoustics
Old 10th June 2013, 01:30 AM   #6
system7 is offline system7  United Kingdom
system7's Avatar
We've all taken speakers apart and then found, in our excitement, we have forgotten to note the wiring polarity!
The good news is that 99% of speakers wire IN PHASE.
As noted, if it's wrong, you get a hollow vague "phasey" sound around crossover frequency.
Really the only exception is where the tweeter is on a simple first order capacitor circuit and the bass is on the usual bass-boost coil. This wires out of phase.
To determine the positive terminal, which is often marked with a red dot, a 1.5V battery briefly touched positive to positive will make the driver move forward.
A 3 way speaker is more complex, and depends on the filter orders. You could find a similar type of speaker here and compare too:
DIY Loudspeakers
Best Regards from Steve in Portsmouth, UK.
Old 10th June 2013, 03:03 AM   #7
Thank you all.
And as it's way past your bedtime, a good night to you System7.
Determining Phase and Gain Margins in LTSpice jkuetemann Solid State 14 10th September 2015 04:34 PM
Phase Cancellation Issues with Din Pocket Tweeters? techbiker Car Audio 3 15th April 2013 08:25 AM
True dipole tweeter or two monopole dynamic tweeters on opposing sides out of phase? SpinMonster Planars & Exotics 2 19th September 2012 11:57 PM
M-AUDIO BX5a monitors : Tweeters out of phase ? jives11 Multi-Way 7 23rd September 2011 11:25 AM
Acoustic phase, electric phase,....phase ermes Multi-Way 6 27th November 2010 07:17 PM
Copyright 1999-2017 diyAudio
