Understanding Danley Synergy ? - Page 7 - diyAudio
Old 16th June 2013, 02:51 PM   #61
JLH is offline JLH  United States
JLH's Avatar
Originally Posted by bear View Post
Art,
I have never heard the Synergy, and have only had cursory contact with the Unity horns... but unless there is something very different between the breakovers in the Synergy vs the MantaRay I'd expect a problem. There may well be some very important differences. I don't know.
As far as "pretty" designs, pretty has nothing to do with the measurements. I expect you followed JMMC's thread, so you've see what I and everyone else has?
Also I think Geddes has commented on the effects of a change in flare rate between the drivers throat where it exits to the expansion of the horn causing issues. I'm unclear how or if the Synergy or any conical expansion deal with this potential problem.
The frequency of the horn loaded woofers (not talking about the mids) is limited to a frequency where the wavelength is less than the circumference of the conical horn's mouth. This all but eliminates any mouth diffraction because the mouth is acoustically large compared to the wavelength that it is passing. The frequencies below this frequency are handled by the bass reflex ports which are too far forward in the horn to be horn loaded. Lastly, Danley puts an extra wide angle ending mouth flare at the end of the horn for good measure.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 17th June 2013, 12:29 AM   #62
expert in tautology
bear's Avatar
If there is an issue with diffraction, it comes higher in frequency than the woofers... I was more focused on the effects upon the upper mids and highs.
It is the sort of "extra wide angle ending mouth flare at the end of the horn" that is of concern to me, if the upper frequencies are "riding" along the horn walls, anything like that will look like a discontinuity.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 17th June 2013, 12:51 AM   #63
Patrick Bateman's Avatar
I'm listening to the Geddes Summas while I type this post, and I've built a bunch of Unity horns. From the perspective of the work that Geddes does, the designs diverge in a few ways:
1) Most listeners focus a lot of attention at the throat of the horn, but I'd say the main difference is the cabinet actually. IMHO the main reason that my Summas 'disappear' is that the cabinet doesn't have a sharp edge *anywhere.* Even the back of the cabinet is designed to reduce diffraction, and this makes a difference. Compare this to the Lambda Unity horns with their rough edges.
2) The curve at the throat isn't perfect, but it's not terrible either. If you look at the polar curves of the SH-50* you'll see their as good as it gets, and I'd guess that they wouldn't be that good if there were substantial issues at the throat. Just my opinion of course.
3) IMHO, higher order modes will be generated in the throat because the midrange energy doesn't go strictly down the axis of the horn; in fact the midranges aren't even *mounted* on the center of the horn, so higher order modes are a given. Is that audible? I don't know; I haven't listened to both designs enough to offer a valid opinion. When I've listened to the designs on the same day, I've found that the Unity wins in the articulation department, and the Summa wins in the imaging department. But the Summa's imaging is partially due to the cabinet, and the Unity cabinet could easily adopt the Summa's shape.
* download the CLF viewer and the CLF files from danleysoundlab.com to see the polar plots
Old 17th June 2013, 04:06 PM   #64
JLH's Avatar
The high frequencies do not "ride" along the horn walls. Those wavelengths are too acoustically small to even interact with the horn wall at the mouth.
Old 17th June 2013, 04:54 PM   #65
ra7 is offline ra7  United States
In Toole's book, he explicitly states that diffraction looks bad on paper, but does not sound as bad. In fact, any type of comb filtering is not perceived the way it looks on the measurements. Floor bounce, for example, produces a comb filtered response, but we don't hear it that way.
Speakers disappearing is primarily down to good phase overlap through the crossover, i.e., proper crossover design, and small center to center spacing of the drivers. You can put two identical speakers side by side, one with curved sides and another with sharp edges, and I bet you won't hear the difference in a blind test. That's just my opinion.
All the reports I have heard about the Synergies are unanimous in their opinion that the stereo imaging is far superior to conventional directional speakers. It's down to the smooth crossover and near-point source behavior of the speaker.
Old 17th June 2013, 11:09 PM   #66
AllenB is offline AllenB  Australia
Yesterday I whipped up a crossover for a new build in a couple of hours...so that I could listen to music while I did it properly The speakers still disappear. The vertical spacing isn't too small either.
Old 19th June 2013, 12:56 AM   #67
expert in tautology
bear's Avatar
Imo, that would depend on a few things.
What frequencies?
Is there any diffraction or other diffraction causing discontinuity at or near the throat?
Why do the JMMC horns (even ones like 200Hz horns) show a smoother response with very large "lips" at high frequencies if there is no effect at the mouth?
_-_-
_-_-bear
Old 19th June 2013, 03:50 AM   #68
thoglette's Avatar
Default Honk
All of which is part of the field information we use for location and "sense of the space". It may not sound bad but it impacts on the sense of realism (which is why everyone recommends damping floor bounce with a carpet)
The beyond the ariel thread has a number of discussions on the role of comb filtering in creating "horn honk".
BTW There's a nice experiment with a magazine and a towel on "horn honk" somewhere on the interweb
Old 19th June 2013, 05:56 AM   #69
Maybe your crossover isn't that bad after all.
How do you explain the disappearance of small speakers, such as the Harbeth monitors, or take Jeff B's Continuums for that matter. There is no rounding of the edges. Besides, there have been many counter-studies that showed that the radius that is typically achieved, like the one on the Summas, has little to no impact on smoothing the abrupt change at the edge.
Now, if we are talking about the LeCleach roundover, yes, that will have a significant impact. Especially on a horn, where it will prevent mouth reflections. That is almost a complete 180 deg roundover that is perfectly... round. That is not to be confused with the puny roundover on a flat baffle.
We are much more sensitive to errors in the crossover, bumpy response, and drivers calling attention to themselves, than we are to diffraction from baffle edges.
Old 19th June 2013, 08:18 AM   #70
thoglette's Avatar
Can you provide a lead on these?
I concur with your comments on small monitors, I've always presumed some mechanism was keeping Q down and htis combined with the short distance made it less noticable.
Agreed. Horn Honk is the extreme form of "the diffraction problem" which is usually audible.
I've not heard the Danley horn but all reports indicate that it does not suffer from this at all.
DIY Synergy horn paulspencer Multi-Way 53 5th December 2015 09:29 AM
Dynamikks Synergy horn angeloitacare Multi-Way 4 22nd July 2013 07:35 PM
Unity/Synergy horn 454Casull Multi-Way 9 10th June 2013 05:35 PM
Synergy Horns johnB23 Full Range 1 2nd June 2012 06:52 PM
synergy like horn, using CD rvrazvan Multi-Way 5 4th November 2011 08:28 AM
Copyright 1999-2017 diyAudio
