Bass unit for shallow enclosure
Old 3rd June 2013, 09:05 PM   #11
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Wall-sub:
b
Old 4th June 2013, 04:36 AM   #12
cT equals piD is offline cT equals piD  United States
Even if you can find a bass unit that will fit into a shallow depth, there should at least be enough space for damping material on the rear wall. Otherwise, assuming a paper cone, the rear wave is reflected off the rear wall and through the cone. Even if the cone is of a material that won't allow sound to pass through it, I would still think the cone very close to the rear wall would cause problems.
Pete
Old 4th June 2013, 05:39 AM   #13
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Yes, that is one of the first considerations to be done. That's why I suggested little
stiff cones which have more impact, i.e. find less air resistance . I was thinking of some side ( of the box ) mounting or inclined respect to the wall . Side mounting, one each side and one with the magnet in sight, in BR with slotted port ( heavily EQ'ed ). Adding some mass to the cone might help in lowering Fs ( and efficiency )
Old 4th June 2013, 11:54 AM   #14
Charles Darwin is offline Charles Darwin  United Kingdom
Pete
There is a cone material which does not allow sound to pass through it?
Old 4th June 2013, 02:21 PM   #15
Polypropylene? That is a kind of plastic resin. I really don't know for sure, but I would think that plastic is relatively much more impervious to sound passing thru it. Strangely enough, it seems that all materials can transmit some sound energy.
-Pete
Old 4th June 2013, 03:20 PM   #16
I'd find it even stranger if polyprop in the thickness used for cones would have any sound blocking properties.
Surely it would be cheaper for studios to be lined with that rather then going through the cost and hassle of building a floating room within a room.
Old 4th June 2013, 06:23 PM   #17
weltersys is online now weltersys  United States
weltersys's Avatar
Pete
Pete,
The OP stated in the OP "The satellites run to 150Hz or so and the woofer enclosure will take over from there."
The wavelength of 150 Hz is 7.5 feet long, "damping material " on the rear wall will have virtually no effect in reflected waves at that low of frequency.
Old 5th June 2013, 01:43 AM   #18
Originally Posted by weltersys View Post
Pete,
Good point. So that means the wave reflected off of the rear wall is very close to 180 degrees out of phase with the sound radiated into free air. Then also there is some cancellation as a result of that that nothing can be done about. Would you agree?
The author of the book that I am referring to about this subject of the wave reflected off the rear wall speaks of the reflected wave passing "right through" the cone. The cone he says is "virtually acoustically transparent". But I think a more correct description would be that the reflected wave (inside the box, off the rear wall) is exerting a force on the cone in opposition to the driven direction. In that way, the reflected wave might be said to in a way to travel "through" the cone.
-Pete
Old 5th June 2013, 08:44 AM   #19
How about this one (comes in 4 or 8 Ohm):
Europe Audio
Old 5th June 2013, 09:40 AM   #20
no way , the Sb acoustics is still to big.
At the very first start of the impulse the acoustic load would be like a very
little PS and very compressed , in terms of pressure . It won't allow high and
durable excursions IMO
Bass unit for shallow enclosureHide this!Advertise here!
Bass platform/ enclosure rock/ blues and HT ** feeling ** the bass otto88 Subwoofers 5 3rd April 2013 03:58 PM
Shallow mid-range enclosure inside a 3-way?? too shallow?? Kooshball Multi-Way 8 3rd November 2012 11:40 PM
Driver recomendation for shallow enclosure prezden Full Range 7 11th September 2012 07:33 AM
Going to use four cvt65 kicker shallow subs for bass and mids... get 2 or 4 ohm? ppia600 Car Audio 2 6th February 2010 02:09 AM
JX92 VTL enclosure with other unit? hatasa Full Range 10 10th September 2006 07:56 PM
