Does anyone have direct experience with the 6.5" seas aluminium drivers, i would like to use some in a 2 way, either TM or MTM depending on my finances when they come around, i know that the woofers have some strange cone breakup up high and so i would also like advice on what to do in the crossover to deal with this, is it jsut a steep slope?
help on any of this would be great |
#2 |
Nearly all metal drivers require a parrallel resonant
circuit to supress the main resonant peak. A high slope crossover is not enough. checkout the crossovers for the kits using metal drivers on the www.seas.no website. |
#3 |
thanks for the reply, i looked at the seas kits crossovers and did not know what i was looking for, can anyone help me out, the woofer that i want to use is the L17RE/P, with the tweeter 27TFFC.
#4 |
Hmmm......
The double peak in the response of the L17RE/P makes it even trickier than the Excel magnesium units which only have one peak. Try this link : http://home.hetnet.nl/~geenius/DD8.html |
#5 |
Sorry,
I only have the Seas Excel magnesium ones with RavenII ribbon tweeters. I bought them as kits from a company in America called Zalytron. See if they have a web site..... Probably Zalytron.com Maybe they can lend a hand. Can't hurt to check. I love mine!!! Good luck, Chris
The best audio is clean audio! |
#6 |
ok i went to that site you mentioned and saw the crossover for both the woofers in question, the woofer that has higher efficiency is only $8 more in aust so that would be better, but the tweeter i want to use is different to that one, what do you think should be done, a change of crossover or not?
#7 |
If you checkout the two tweeter specifications at www.seas.no
you'll see that they are as near identical as your likely to find. So you can use either tweeter with the crossover. |
#8 |
ok thank you, that works well then, thanks sreten, i really should learn more about crossovers,
but yes until i know alot more and especially for my first speaker project i will look for crossovers i can copy. thanks sreten |
#9 |
A way more than simply sensible approach IMO.
But note that as long as you keep the baffle width the same with a crossover you do still have some choice of enclosure volume and bass alignment. |
#10 |
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| WTB: Seas Vintage Pestige series 8" woofers | omarmipi | Swap Meet | 2 | 21st April 2008 01:56 PM |
| SEAS 2way | tpsorin | Multi-Way | 29 | 28th July 2007 08:50 AM |
| Seas 2Way Cabinets | ndc_11 | Multi-Way | 2 | 5th July 2005 02:48 PM |
| Seas 2Way. | Baronty | Multi-Way | 10 | 20th October 2004 07:24 AM |
| Page generated in 0.10190 seconds (81.59% PHP - 18.41% MySQL) with 10 queries |
