Help for 3 or 4 way loudspeaker - Page 38 - diyAudio
Old 13th March 2014, 05:43 PM   #371
merlin el mago's Avatar
Left woofer
1k7-3k1 0.012-0.013
3k2-4k4 0.013-0.013
Old 13th March 2014, 05:50 PM   #372
Where is the centre of the "flat" range, where the voltage does not change appreciably of each woofer?
Old 14th March 2014, 11:48 AM   #373
I'm doing well the drivers measurements?
Old 14th March 2014, 06:50 PM   #374
Please help.
Old 21st March 2014, 01:09 PM   #375
Inductor's Avatar
Originally Posted by merlin el mago View Post
Please help.
What are you trying to do?
Seas tweeter E0011-06 T25CF002
Tweeter rolls off at 11/12 (13KHz) as you can see from the FRD so that should not be a problem. (You can check the ZMA files also that follow below and match them with your driver)
http://www.rjbaudio.com/Audiofiles/F...%20T25-002.frd
http://www.rjbaudio.com/Audiofiles/F...%20T25-002.zma
Old 21st March 2014, 05:03 PM   #376
Limp measurements 110 ohms resistor
1st pic SS 18W-8545-00 left
2nd pic SS 18W-8545-00 right
3rd pic Seas Millenium left
4th pic Seas Millenium right
Old 22nd March 2014, 09:45 PM   #377
Attached new measurements, 1st pic SS-18W8545-00 left channel, 2nd pic SS-18W8545-00 right channel, 3rd pic Seas Millenium left channel and 4th pic Seas Millenium right channel. I guess now are OK
Old 23rd March 2014, 03:28 PM   #378
Post 377 with measurements done with 100 ohm reference resistor, how I to proceed with the information to make my xover?
TIA
Felipe
Old 23rd March 2014, 09:09 PM   #379
Inductor's Avatar
You are not using simulation (FRD/ZMA's files)?
Old 23rd March 2014, 10:41 PM   #380
I don't know how to use it....
my 3 way loudspeaker camaro71 Multi-Way 90 12th January 2012 10:33 AM
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 83 16th May 2011 12:27 PM
new loudspeaker steve_mak Multi-Way 15 14th December 2006 12:41 PM
Dayton Loudspeaker. jadenlinkletter Subwoofers 2 17th October 2005 02:00 PM
Loudspeaker limericks Cal Weldon Multi-Way 54 1st January 2005 06:18 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
