Help for 3 or 4 way loudspeaker - Page 2 - diyAudio
Old 25th May 2013, 07:16 PM   #11
Inductor's Avatar
internal measurements?
Old 25th May 2013, 07:39 PM   #12
Inductor's Avatar
I think one woofer (with one inductor+rc maybe) could work, but I don't know what you have in mind. In this case I would test the (1x) SB ACOUSTICS for sub and adjust variant internal R in the L1 coil for the main driver.
If for one driver as above (30,5cm x 34cm ext.) for 70 L.
Height in cm: 95, Width in cm: 30.5, Depth in cm: 34, thickness in cm: 2.2
Strassacker: Speaker Building, Components
You can use any vol. calculator.
Old 25th May 2013, 07:44 PM   #13
merlin el mago's Avatar
The thicknes of the wood is 2 cm, the rest of measures are:
High 36 cm
Top 13,5 cm width
The internal structure is Matrix type, attached pics, the left side pic is the tweeter hole so the loudspeaker have three braces internally all with holes.
Old 25th May 2013, 07:50 PM   #14
I'm sorry for a lot of questions: what about the BR, front, rear, diameter hole, depth of tube, position, etc? link to calculate & see the best position, etc?
Old 26th May 2013, 02:22 AM   #15
Inductor's Avatar
That's confusing, no?!
Old 26th May 2013, 09:56 AM   #16
Yes a lot confusing, all questions are about the bass reflex hole:
-Where to do the hole: front or rear
-Position of the hole: near the loudspeaker of two ways, in middle or near the soil. Centered or in the interior side or in the exterior of the box.
-Diameter of hole
-Length of the pipe to tune
-Etc.
Your help is really appreciated.
Old 29th May 2013, 12:21 PM   #17
Help please
Old 30th May 2013, 12:17 AM   #18
If your speakers will be close to a wall with their backs a port on the rear is out of the question straight away.
The diameter (or area) and length of the port should be given to you by whatever software you use to design the speakers. It will depend on the particular driver and the tuning you choose.
Old 30th May 2013, 10:54 AM   #19
I don't have problems: I have space rear the speakers.
Old 30th May 2013, 11:04 AM   #20
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I'm sorry for a lot of questions: what about the BR....
why BR ?
I would suggest acoustic valve(apperiodic), if you want your top/mid 'vented'
My idea is two woofers in parallel like Watt & Puppy, but I'm oper to other ideas/suggestions.
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 130 14th June 2016 11:21 PM
my 3 way loudspeaker camaro71 Multi-Way 90 12th January 2012 11:33 AM
new loudspeaker steve_mak Multi-Way 15 14th December 2006 01:41 PM
Dayton Loudspeaker. jadenlinkletter Subwoofers 2 17th October 2005 03:00 PM
Loudspeaker limericks Cal Weldon Multi-Way 54 1st January 2005 07:18 PM
Copyright 1999-2017 diyAudio
