Hey all,
After waiting and waiting to install my much nicer components in my car, I've decided I don't really need them there. (nor do I really want to do the custom fiberglass etc.) So I've got this really nice set of components with a Madisound XO, and all they need is an enclosure. I've got the following: Peerless CSX 176H Morel MDT 39 Madisound Crossovers And using WinISD I've come up with an enclosure with interior measurements netting 10"x18"x13" (1.4 cubic feet, 34.2l) with a 3" port 10.25" long setting the tuning at 35.6Hz. Does this sound right to everyone? (I have tacked a bit onto the total volume to make up for driver displacement, XO displacement, and bracing. WinISD's measurement was exactly 1.207 ft^3)
-Hank |
#2 |
I'm curious as to the construction of the XO. Was it designed for those specific drivers?
#3 |
All i'll say on this is assuming the Madisound croosovers are
correct for in car use they will not compensate for 'Baffle step diffraction' loss which occurs in free standing loudspeakers and the bass will be shelved down. Alternatively the XO you've bought is designed for domestic loudspeakers (and should have never be used in car) so as long as you stick to a sensible baffle width it will be fine. With Vas = 28 litres you start chasing your tail going beyond this for box volume, your parameters sound fine, but TBH you wont lose much going to 25/30 litres and 35hz. |
#4 |
Even if it was intended for those drivers and home use isn't the impedance of the driver affected by the enclosure to some extent?
#5 |
Not at frequencies relevant to the crossover
#6 |
the XO was designed for use with these drivers.
So what you're saying, sreten, is that I'm overbuilding? (too large?) Could you suggest some alternatve measurements?
-Hank |
#7 |
35 litres isn't overdoing it unless a major concern is cabinet size.
The crossover should be designed for the specific drive units for domestic use and for a specific cabinet width - which you should be able to get from Madisound. Given the cabinet width which is usually around 9 inches total, the other two exterior measurements are not critical. If size is an issue then I'd recommend 25 litres tuned to 35Hz. Still quite a big cabinet for a 6.5 incher. |
#8 |
Have a look at the Peerless data sheet which has recommended volumes and tuning.
http://www.wescomponents.com/peerless/850122.pdf Used 30 litres on mine. Try tuning the port at several frequencies. I ended up with 44Hz, appears to be too high, but it just happened to sound better in my room with my equipment and probably due to a bit of a peak between 50-70Hz. |
| Custom Home Theater Project in New Home, Opinions appreciated. | thadman | Multi-Way | 5 | 20th November 2008 12:40 AM |
| Which is best choice of driver for Home Theater speaker 5.1 DIY project? | langtuhanoi | Multi-Way | 5 | 28th September 2008 03:32 PM |
| Speaker measurements in the SF Bay Area | neil_kaye | Multi-Way | 1 | 21st May 2008 04:20 PM |
| speaker measurements | kendt | Full Range | 7 | 5th February 2007 08:57 AM |
| Does anyone have the a speaker workshop project with Seas 27TBFC/G measurements? | owdi | Multi-Way | 1 | 3rd August 2006 03:06 AM |
| Page generated in 0.10349 seconds (69.51% PHP - 30.49% MySQL) with 10 queries |
