Anyone used the Vifa M18 7" in as the bottom end in a 3 way design?
Mos |
#2 |
I have not done this but i could assume that it could be very nice, but it already extends high enough to use in a 2way with a capable tweeter. what would you plan on using as the mid and high?
#3 |
Hi Michael
P13 as the mid and XT25 as the tweeter. Xoed at around 250 and 3000. Mos |
#4 |
with no experience on these drivers i cant really make actual recomendations but i can give you my two cents, i think that a 3 way with the XT, the 3" mid dome (D75MX) and then the M18, maybe with a crossover of 750Hz and 4.5KHz. my reasoning behind this is that the lower midrange smoothness of the M18 should not be wasted.
what do you think? |
#5 |
Mmm, the experienced heads around here (not mine) might say that in it's price range (and somewhat beyond) there's nary a driver smoother from 300-3000 than the P13.
Besides, the idea of crossing the M18 lower rather than higher is to relieve it of the job of handling mids and hand that off to a specialty mid driver, as the P13 is considered. Mos |
#6 |
ok, so why not use an 8" or 10" for below 250Hz which would have much lower response. and it would not be dealing with anything higher which naturally they do not handle well.
#7 |
My company sells a kitset called the AKSonic with a complex, carefully engineered crossover using the Vifa M18 and the X25T ring tweeter in a two way.
This is an exceptionally good combination, with gorgeous imaging, unbelievable detail and wonderful engagement. The M18 has a very strong motor (BIL of 7.5) with very high mechanical Q (6.7). This makes it place rather than play the note. Recommended. Cheers, Hugh |
#8 |
Hi, Hugh
You think the M18 has good potential to be crossed over low in a 3 way? The results I've got from LspCad show a good F3 of 35hz in a 55 litre box tuned to 34hz. Michael: I was thinking about the Vifa M22 8", built for smaller vbs and with and Fs of 26hz. It's just a lot more expensive, that's all, and when you're buying 4 woofers that can get out of hand. -------- Furthermore, Keith Kidder (Hi, Keith) gave me an idea when he suggested that the Vifa M series drivers were a poor man's scanspeak. If you try modelling the drivers, dual M18s, P13 and XT 25, they could be made to perform (and look Anyone? Mos |
#9 |
Mos,
I like these Vifas. Half the cost of th 8545 Scanspeak, and maybe 90% of the quality. I don't see them as a poor man's Scanspeak; rather, I see the Scanspeak as a cynically marketed speaker for the DIY perfectionist....... Yes, these drivers will do fine crossed over low, BUT, they are also a midrange speaker, up to 2,500Hz is just fine, and I see this as a waste. I prefer to use two ways, and augment with a sub. I feel this has less damaging effect on the music in that essential 200Hz-3KHz range where most of the imaging is found. A three way uses a band pass filter and their effect on phase is horrific. Cheers, Hugh |
#10 | |
Hugh said:
Mos |
| Modulus 3way | Jamesuk1 | Multi-Way | 5 | 20th April 2008 04:49 AM |
| 3way design | Paulus1981 | Multi-Way | 1 | 20th October 2007 09:40 PM |
| 3way with bandpass sub | tinitus | Multi-Way | 29 | 9th August 2007 03:01 PM |
| 2.5 or 3way | deki | Multi-Way | 13 | 18th July 2007 02:33 PM |
| Page generated in 0.14626 seconds (75.66% PHP - 24.34% MySQL) with 11 queries |
