Extremely Basic Low Pass Filter Question
Old 11th May 2013, 01:04 PM   #1
miragem3i is offline miragem3i  China
Default Extremely Basic Low Pass Filter Question
I want to create a low pass filter and just understand this point better.
Reactive Capacitance is:
XC= 1 / ( 2πfc)
Where c is in farads and f is in hertz.
I want to calculate the rolloff and cutoff frequency for a given value of capacitance - let's assume 4.7uf - at a given frequency.
How do I calculate this roll-off/cutoff frequency of a low pass filter with only one capacitor in the circuit?
Example a woofer connected to a tweeter with a 4.7uf wired across the woofer terminals. What's the rolloff/crossover frequency?
TIA!
Old 11th May 2013, 06:20 PM   #2
jjrenman is offline jjrenman  United States
First, lets go over some basics. A single capacitor in series with the tweeter is a 6db/oct high pass. A single inductor in series with the woofer is a 6db/oct low pass. I don't know of a situation that you would put a lone capacitor across the woofer.
Second, your formula does not look correct. For speaker applications the formula will take into account the impedence of the driver.
Old 12th May 2013, 01:40 AM   #3
Originally Posted by jjrenman View Post
I don't know of a situation that you would put a lone capacitor across the woofer..
My mistake.
So how to calculate the xo frequency for that 6dB/octave high pass filter using only one capacitor?
I obtained that formula from several difference sites. What is the correct formula.
Old 12th May 2013, 01:54 AM   #4
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Think of it a different way... imagine the capacitor as a (frequency-dependent) resistor. Picture the circuit with that resistor, rather than a capacitor. And keep in mind that current flows through the path of least resistance.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 12th May 2013, 02:05 AM   #5
Right, that is how I think of it. So given that it is a frequency dependent resistor, what would be the way to calculate the crossover response of said capacitor with a given driver? I wish to calculate where to cut off the high pass at a given frequency.
"For speaker applications the formula will take into account the impedance of the driver. "
Ok. So this formula would be...what?
Old 12th May 2013, 02:23 AM   #6
Jerrym303 is offline Jerrym303  United States
Not an expert or even experienced, but these pages might help:
Passive Crossover Networks
Passive Crossovers, Capacitor and Coil Calculator
Old 12th May 2013, 02:33 AM   #7
counter culture is offline counter culture  United States
The 3dB (half power) point (generally quoted as the nominal frequency of the network) of a 2 component network is where Z1 = Z2.
So in the case of an RC network (one resistor and one capacitor), the power will be split 50/50 across the 2 components when R = Xc, or R = 1/(2*pi()*f*C).
You can jiggle this around to get f = 1/(2*pi()*R*C).
Now I am Become Death, the Destroyer of Words
Old 12th May 2013, 02:34 AM   #8
sofaspud's Avatar
C = 1/2πfR
where R is the driver impedance
or f = 1/2πCR
Old 12th May 2013, 02:50 AM   #9
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
First Order Formulas
Note, top of both formulas, the 159,155 has a comma, the second one is a decimal point.
----------------------------------------------------Rick........
Last edited by Richard Ellis; 12th May 2013 at 02:55 AM. Reason: Maybe can't see it.
Old 12th May 2013, 11:50 AM   #10
Pano is offline Pano  United States
Pano's Avatar
This calculator is also very good and easy to use.
2-Way Crossover Designer / Calculator
Instructions are here:
3 Way Crossover
Take the Speaker Voltage Test!
Extremely Basic Low Pass Filter QuestionHide this!Advertise here!
simple low pass RC filter noob question mr.duck Parts 18 18th October 2015 10:37 AM
multiple feedback low pass filter question graygem Analog Line Level 20 14th July 2011 06:01 PM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Extremely basic ward cleaver Construction Tips 3 29th December 2009 11:16 PM
Low Pass Filter question synthius Chip Amps 18 28th February 2008 12:13 PM
