Old 2nd December 2003, 06:03 AM   #1
Default Mounting a driver on a curved baffle...
I am making some wall-mount speakers using half-pipes of PVC, what is a good simple technique for mounting the flat driver frame on a curved baffle?
Old 2nd December 2003, 02:00 PM   #2
Default A simple way ?
As far as I know there is no 'simple' way of doing this.
It depends on the size of the drivers relative to the radius and
thickness of the pipe, and whether the drivers sit under the
outside curve of the pipe, or subbaffle is used in front of this
surface.
/sreten.
Old 2nd December 2003, 02:09 PM   #3
diyAudio Moderator Emeritus
roddyama's Avatar
Default Re: Mounting a driver on a curved baffle...
What is the diameter of the PVC and what is the diameter of the driver?
Rodd Yamashita
Old 2nd December 2003, 05:19 PM   #4
richwalters's Avatar
A pity you are using wood as you can"cut and shut" creating a jagged curve then glue all thenwhen set smooth all down using a bastard or a sander. Either way seems laborious and you need a fair thinkness of wood to do it and all depends on the circumference and size of drivers used. Elliptical drivers ?
rich
Old 2nd December 2003, 05:32 PM   #5
Bose(o) is offline Bose(o)  Canada
Wouldn't necessarily be an easy way, though, it would work. You could use fibre glass, and it would mould to the curvature that you'd like.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 2nd December 2003, 10:41 PM   #6
I'd be easy enough to cut something out on a band-saw, but it all really depends on what you want.
Old 2nd December 2003, 10:52 PM   #7
The pipe is 4 1/2" PVC, a quarter-inch thick. The drivers are 3" Tang Band 371's. I really want to mount them as flush as ****ible, if it IS possible. I realize I may have to have them a bit raised on a small baffle of some sort, but I still am hoping to find an easy solution, if available.
Old 2nd December 2003, 10:55 PM   #8
I know there is a company that makes heavy cardboard pipes for speaker building, I wonder what they have in mind for people that buy their tubes.
Old 2nd December 2003, 11:30 PM   #9
Default baffle
I had a go at this on some 100mm pipe;
I mounted the drivers on a flat baffle, glued some foam around the edges of the baffle, cut out a piece of the pipe to match the baffle, then screwed the flat baffle to the pipe.
With small drivers, you may be able to cut out an appropriately shaped mounting 'ring' from solid foam (the sort they use to line road cases etc); when the driver is screwed to the pipe there should be enough pressure to prevent any air leaks...???
cheers,
Pete McK
Old 2nd December 2003, 11:54 PM   #10
I like that idea, except I might have the screws go through some little plastic or wooden cylinders before they go through the PVC, just so they are mounted on something solid. I worry that if I had too much foam between the frame and the PVC, I might have problems with an unstable mounting surface.
Starting a curved baffle dipole woofer array project Few Multi-Way 42 19th May 2010 01:47 PM
OPen baffle mounting and decoupling advice irishpatrick33 Planars & Exotics 6 17th June 2009 11:25 PM
curved front open baffle pforeman Full Range 0 20th February 2009 12:38 PM
The Igloo Project...curved Open Baffle For Visatons foniton Full Range 4 12th September 2006 07:56 PM
Mounting a Speaker to a baffle Peter Menting Multi-Way 12 3rd March 2005 06:25 PM
Page generated in 0.11764 seconds (68.48% PHP - 31.52% MySQL) with 11 queries
