Mounting a driver on a curved baffle...
Old 3rd December 2003, 12:54 AM   #11
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Get a PVC "T" and cut the "T" off as close to the pipe as possible. This will provide the flat surface on which to mount your driver. If you feel that the straight "T" is too large of a flat surface, get a reducing "T" (4" straight to 3" "T"). That will give you a 3-1/2" diameter "baffle" surface.
Rodd Yamashita
Old 3rd December 2003, 01:05 AM   #12
StereoG is offline StereoG  New Zealand
Originally posted by The Paulinator
The pipe is 4 1/2" PVC, a quarter-inch thick. The drivers are 3"
Here's an idea.
Use a ~3" piece of tubing for a connecting piece (ie the driver to be mounted on its end)
Use a program like tubemiter or winmiter to make a template for the notch on the 3" pipe, cut it out, and mark & cut the hole on the 4 1/2" pipe. Cut the 3" pipe as short as you dare afterwards, ie to a minimum.
Both are windows programs. tubemiter looks slightly more basic in its interface, but does the same job.
tubemiter.exe (and tubemit3.txt )
http://www.ihpva.org/tools/ (near bottom of page)
winmiter.zip
http://home.tallships.ca/mspencer/winmiter.html
Old 3rd December 2003, 02:33 AM   #13
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Tubemiter Kewl!
I wonder if it works on valves too?
Old 3rd December 2003, 05:35 AM   #14
The Paulinator is offline The Paulinator  United States
Wow, that's some good thinking. That might be the best way to go. My only concern is that most 'T's have larger ends to act as female receptacles for other pipes, so I'll have to figure a way to disguise or get rid of that. Or if I can find one that is long enough that I can cut the larger ends off and still have enough pipe for a decent sized enclosure, that might work.
Good idea.
Mounting a driver on a curved baffle...Hide this!Advertise here!
Starting a curved baffle dipole woofer array project Few Multi-Way 42 19th May 2010 01:47 PM
OPen baffle mounting and decoupling advice irishpatrick33 Planars & Exotics 6 17th June 2009 11:25 PM
curved front open baffle pforeman Full Range 0 20th February 2009 12:38 PM
The Igloo Project...curved Open Baffle For Visatons foniton Full Range 4 12th September 2006 07:56 PM
Mounting a Speaker to a baffle Peter Menting Multi-Way 12 3rd March 2005 06:25 PM
