Hi guys,
Just a few months ago I took apart my speakers out of curiousity and realized that for the money I paid and a little bit of research I could do a better job...nothing new to you guys What I do need some help with is cross-over design theory, basically a know very little (see below) and would like to learn about the various design/implementations used in the loudspeaker industry today. If any of you have come across and relevant material be it a website or textbook or anything else, please let me know. Btw, I do have a book "Microelectronic Circuits 4ed" by Sedra/Smith but that only deals with 1st and 2nd order butterworth and chebyshev filters. I've started reading about TL speakers...very interesting stuff. Cheers! |
#2 | |
True Audio has some interesting on-line reading. A good book to "cut your teeth on" is The Great Sound Stereo Speaker Manual by David Weems. If you want more, many recommend Vance Dickinson's book The Loudspeaker Cookbook.
#3 |
Try Martin Colloms 'Loudspeakers' book.
P.S. a little knowledge is very dangerous when it comes to building your own loudspeakers ! |
#4 | |
#5 |
Check out http://ccs.exl.info/calc_cr.html
Also, get your hands on a free trial copy of Electronics Workbench. I've found it really useful in designing both passive and active crossovers. CM |
#6 |
Here is a couple to have a look at as well
http://hyperphysics.phy-astr.gsu.edu.../cross.html#c1 http://www.crossovers.com/index001.html http://www.eatel.net/~amptech/elecdisc/xoorder.htm fairly basic sites hope they help |
#7 | |
Well is not that difficult to build an amplifier that does moreorless what you expect it to, assuming you can get it to work, and don't blow it up at some point. Conversely without understanding all the factors involved, designing and building a loudspeaker that does what you expect it to is very, very difficult. Taking everything into account, and getting the compromises right between various aspects of the performance is a minefield for the beginning designer / builder. But there are some well documented and measured good amateur designs out there. Your best bet is to understand more and then find a good design that suits your requirements and build that. |
#8 |
It's just a matter of understanding the theory and the associated variables (Qes,Qms,Fs...etc etc)
The next issue is mating a tweeter+woofer that will sound good together. PS: I'd like to built my own kit (box & cross-over) from scratch if possible since finding the particular drivers used in other kits can sometimes be either too difficult or too expensive depending on where you live. |
#9 | |
#10 | |
This is one of those things that looks easy, but isn't. The more I learn about this, the more I learn that I don't know. Regards Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
| Calling all DIYers in JAPAN | Spectrum77 | Multi-Way | 0 | 30th January 2009 04:09 AM |
| Cable construction question for the ee knowledgeable. | Colescuttle | Parts | 9 | 12th May 2007 11:20 PM |
| how did you become so knowledgeable in the field of audio electronics? | osu1177 | Everything Else | 15 | 24th September 2006 12:18 AM |
| hello diyers | semperfidelis | Introductions | 3 | 14th September 2006 04:24 PM |
| Calling all London and SE DIYers | pinkmouse | Everything Else | 13 | 11th December 2002 01:40 PM |
| Page generated in 0.12655 seconds (76.29% PHP - 23.71% MySQL) with 10 queries |
