Looking for 10-inch speakers with a QTS 3.0
Old 1st May 2013, 05:59 PM   #11
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Originally Posted by whgeiger View Post
I am uncertain how that pertains to me looking to replace six 10-inch drivers with a QTS of 3.0 I damaged 20 years ago for a pair of column boxes. I have two originals that are working so I know the driver’s strong and weak points.
OMNIFEX
Old 1st May 2013, 07:53 PM   #12
R.I.P.
Pyramid Studio Pro WH10 10" Woofer Accordian Surround 290-262
The above is near 2. I wouldn't be too precious about hitting 3,
and I'd ditch the last two working drivers, go all new drivers.
rgds, sreten.
Old 1st May 2013, 07:54 PM   #13
whgeiger is offline whgeiger  United States
Default Outlines System Design using High [QTS] drivers.
Originally Posted by OMNIFEX View Post
I am uncertain how that pertains to me looking to replace six 10-inch drivers with a QTS of 3.0 I damaged 20 years ago for a pair of column boxes. I have two originals that are working so I know the driverís strong and weak points.
The matching problem (Drivers to Enclosure) is not tied to a single driver dimension [QTS]. That is what the referenced post is telling you. You may relax the [QTS] requirement somewhat if [QMS] & [Fs] are close. In any case for best results, as stated before, replace or rebuild all the 10" drivers. WHG
Old 1st May 2013, 08:27 PM   #14
R.I.P.
Qts and open baffles have little to do with column PA speakers, unless
the PA speakers are open backed and then effectively folded baffles.
High Qts is not now common but it was. High Qts implies small magnets
and low midband efficiency, but can correct baffle step to a degree, giving
a richer vocal reproduction, and relatively good bass efficiency on the cheap.
rgds, sreten.
Old 1st May 2013, 08:37 PM   #15
Hentai is offline Hentai  Japan
How sure are you they were really having Qts= 3.0? Check the ones that you still have again. Some pictures can reveal certain construction features also perhaps there are some part numbers on the pair you have.
Old 2nd May 2013, 12:21 AM   #16
OMNIFEX's Avatar
I already had 10's that are somewhat close in the QMS & fs of the original 10's in the column boxes. However, a QTS of 0.4 sounds anaemic to a QTS of 3.0
It will be difficult for anyone to comprehend the tonal difference unless they have drivers with a high QTS within that region to make a comparison. Id rather use a QTS of 2.0 on those Pyramid's sreten suggested for it will offer closer results to 3.0
And knowing Pyramid's history the QTS is more than likely higher than 1.98
Here is a wav clip of what two old 10’s with a QTS of 3.0 sounds like in one column box sitting on top of another box with the microphone around 12 feet away.
http://www.filedropper.com/twooldtensinonecolumnbox
OMNIFEX
Old 2nd May 2013, 10:56 PM   #17
Default Drive Signal?
Here is a wav clip of what two old 10ís with a QTS of 3.0 sounds like in one column box sitting on top of another box with the microphone around 12 feet away.
Were you driving the 10's with a separate amplifier?
Old 2nd May 2013, 11:13 PM   #18
R.I.P.
Putting low Qts drivers into older radios, radiograms, jukeboxs and
the like is a sure fire way of losing most of the warmth they have.
rgds, sreten.
Still I'd regard a Qts of 3.0 as OK for such things, which typically
have perforated backs and are folded open baffles. For a box Qbox
can only go up, even well stuffed, Qts = 2 should work as well as 3.
Old 3rd May 2013, 04:38 AM   #19
chazdrumzalot is offline chazdrumzalot  United States
mmm....that's good stuff.
Then again, what do I know?
Old 3rd May 2013, 06:46 AM   #20
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
i know some of visaton low budget hifi stuff have Qts of about 1.5 but i doubt Qms would be close, and i also doubt they suit PA at all. WS250E if i recall is the model.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Looking for 10-inch speakers with a QTS 3.0Hide this!Advertise here!
10 inch sub in a pick-up Dan2 Car Audio 14 4th June 2012 01:41 PM
Can I run a 10 inch JL audio and a 12 inch JL audio off same amp ash4kel Car Audio 2 8th April 2011 02:12 AM
Which 10 inch kits ? qguy Subwoofers 3 30th May 2008 12:27 AM
Resistor to change Qts of 12 inch driver ashok Multi-Way 0 26th May 2007 02:19 AM
JL W3v3 10-inch or 12-inch? bad1301forlife Subwoofers 1 1st April 2007 09:05 AM
