Old 1st December 2003, 02:09 PM   #1
Smile 2.5way to reduce F3 for 3" woofer
Bravox 3" woofer available at partsexpress has Fs of 150 Hz. There is an example of a 2way with Tang Band tweeter. Can I throw in another Bravox 3" woofer and get down the F3 to say 80Hz. How will it sound? The XMAX is just 1 mm. Can anyone predict the success of this combination? I am willing to go active
Audio enthusiast/hobbyist
Old 1st December 2003, 03:11 PM   #2
IMO the Bravox unit doesn't qualify as a bass unit and
will be next to impossible to get down to 80Hz by adding
an identical unit.
You could add a better bass unit in parallel, but if you add
the cost of the two units perhaps starting off with a better
unit for 80Hz would be a better idea ?
/sreten.
Old 2nd December 2003, 11:33 AM   #3
Add weight to the cone.
Old 2nd December 2003, 12:46 PM   #4
HI SS,
Adding weight to the mid driver is a no-no.
Adding weight to the 'additional' driver won't work for several
reasons, tiny Vas, Q is too high, excursion is too low.
To get Fs down an octave, 150 to 75hz you need to quadruple
the wieght of the cone and efficiency will go completely down the
pan, so it would be pointless to add.
These are simply not bass drivers of any sort, look at the Vas for
a start, (then Fs, Q and excursion)
/sreten.
Reduce "pop" noise when power on/off veckans Class D 11 28th January 2009 09:53 AM
"reduce rail voltage 20% > pick up on sonics" rick57 Solid State 7 13th April 2006 12:45 AM
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 3 2nd January 2006 02:04 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 07:54 AM
Page generated in 0.07819 seconds (68.75% PHP - 31.25% MySQL) with 10 queries
