I suggest to keep the drivers isolated, whatever a tweeter from the woofer
or the woofer from the ground ( which is difficult because OB likes to have
1/4 pi reinforcement ). Not strings or low elasticity chords but use rubber bands. The best thing to start from is to build a frame ( sort of....a dolly)
and ...
From the technical electronic/ transducer part, I'm more well versed for 3 way design, where active crossover plays a part too: that's why I suggest to take some existing 3 way speaker with sufficient wattage . or use a 2 way, but the tweeter is usually crossed too low.
Because OB ....
and ...
Because OB ....
- Want to try OB-need suggestion for plans
