didn't get it right - Page 2 - diyAudio
Old 29th April 2013, 07:40 AM   #11
System7, is that a 3d order Butterworth? How well would it match up with the older Focal in your opinion? ..... What I've been show is a 16 res connecting + and - : then a 1 ohm res on the + : next a .5mh between + & - : and finally a 15uf on the + line. What program did you use? What's your home audio equipment and speakers?.. my XO may be wrong so I'll have it checked again. Thank you for your time and effort..
pkitt, I agree with you, (I like the clean and open sound, imo.) What did your XO look like? Do you have any pics? What is your home system of equipment...thanks
Old 29th April 2013, 08:16 AM   #12
System7, or anyone; the spec sheet for the Focal is in #1 post and my problem is trying to use this, to make the crossover, anyone with WINpcd or other updated program? thanks in advance...
Old 29th April 2013, 01:55 PM   #13
pkitt is offline pkitt  United States
For the two designs that used the XT19 tweeters, both were 3-ways that used a 2" dome midrange, one an MDM55 and the other an RS52A. I no longer have either of those pairs of speakers. My electronics consist of a Linn Wakonda preamp, Linn Ikemi CDP and Quad 909 power amp, and I also have an HD Radio tuner for local classical music on FM. I generally only build 3-way speakers but my current speakers are 2-ways using an 8-inch, RS225-8 with an RS28F tweeter, called the RS duets, with the cabinet being a mass-loaded TL. I've attached a photo of the RS duets which won first place in their category at last year's MWAF.
Paul
Old 29th April 2013, 05:43 PM   #14
system7 is offline system7  United Kingdom
system7's Avatar
audio4him, those parameters you included are flippin' useless to design a crossover.
Says something about the suitable 15L closed box, but that's about it...
I am entirely following my intuition here and a frequency response from Monacor for the similar SPH-165CP.
On second thoughts, a standard sort of 3kHz bass filter is indicated for the extended response of a Glass Fibre cone. I really have no idea about tweeter level, and the second tweeter capacitor of 10uF would be better if the tweeter is less efficient than I guessed and the input resistor is smaller than 6 ohms. It's just how filters work. And this is diyaudio, after all.
The 6kHz tank across the bass coil might straighten out the phase a lot on a flat baffle. But I'd think this is all doable with some fiddling on resistors. The bass filter won't be a million miles away from where you want to be. Listening will determine the tweeter filter details. Best I can do in such a vague situation. 2nd order bass, 3rd order tweeter should work well.
Best Regards from Steve in Portsmouth, UK.
Old 29th April 2013, 09:34 PM   #15
Originally Posted by balerit View Post
I have been designing crossovers and writing books on the subject for 20 years, show me one source that says you can.
That's interesting - an appeal to one's own authority...
Old 30th April 2013, 07:25 AM   #16
system7 Thanks for trying the impossible to get this given the information you had from this post. I did call the representative here at Focal and he stated there were no more spec sheets. I will go on line and check a few other sites and see if there is any luck. I am not sure if you meant there was also limited information from Vifa, but I will also give a call out and hopefully rectify this situation. Thank you again for your time and effort and I appreciate your help.
I see this morning was rather chilly for you and it looks like a windy week is up and coming. All the best to you and yours.....Danny
pkitt: really great equipment by the way, what's your favorite musical styles?
Old 30th April 2013, 01:57 PM   #17
Thanks, I just recently had my Ikemi "tuned up" and hope to get another 6-7 years of use out of it because I love it. I listen primarily to instrumental symphonic music with a bit of jazz (small ensemble and big band) thrown in. I have only a few CDs with vocal artists.
Paul
Old 30th April 2013, 06:45 PM   #18
badman is offline badman  United States
Custom Title
badman's Avatar
Appears to have been trolling- post nonsense then disappear quickly
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 30th April 2013, 09:39 PM   #19
system7:
Old 30th April 2013, 09:42 PM   #20
system7, these are the best I can get; presently, or until someone has any additional information. Is there any improvement with this information? thanks again
Copyright 1999-2017 diyAudio
