Old 29th November 2003, 11:00 PM   #1
Default Midrange loading theories
Hi
I've seen three ways that builders load the midranges in their systems:
a) sealed
b) ported
c) open-backed
Under what circumstances is each method best and/or applicable?
Thanks.
Mos
Old 29th November 2003, 11:07 PM   #2
Basically a) nearly allways.
sometimes b) for hybrid* systems
(*top unit can also be be used on its own)
c) extremely dubious for drive units as they are comphrehensively
outperformed by planar units in this application, due to the drive
unit giving up any low frequency advantage it may have in the
other loading applications.
sreten.
Old 29th November 2003, 11:20 PM   #3
Brett's Avatar
Default Re: Midrange loading theories
d) horn
Old 30th November 2003, 09:07 AM   #4
frugal-phile(tm)
planet10's Avatar
e/ transmission line
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Applying accoustical theories for combustion engine tunning .. JinMTVT Everything Else 30 17th August 2007 02:32 PM
Anode Loading Vs. Cathode Loading ? valveitude Tubes / Valves 19 22nd July 2005 10:00 PM
Box Design theories trailsnail85 Car Audio 2 10th August 2004 04:25 PM
Help required regarding optical motional feedback theories eclipse Multi-Way 27 6th April 2004 03:03 PM
Page generated in 0.05851 seconds (78.79% PHP - 21.21% MySQL) with 10 queries
