Restoring Electro-Voice Sentry IV-A
Old 1st May 2013, 04:47 AM   #21
Carl_Huff is offline Carl_Huff  United States
Geary,
I presume that you reconed those drivers yourself. Where did you get the kits from?
Best Regards,
Carl Huff
Old 1st May 2013, 05:35 AM   #22
galyons is offline galyons  United States
Originally Posted by Carl_Huff View Post
Geary,
No, just re-foamed the surrounds. Given the age of the paper cones, although in very good condition, I did give them a light coat of the glue diluted with water to about the consistency of skim milk. Went heavier at the surround area and the cone neck.
I have had good luck with Simply Speakers for recone kits and Orange County speakers for in-shop recone.
cheers,
Geary
Old 1st May 2013, 05:35 AM   #23
freddi is offline freddi  United States
freddi's Avatar
if I space, I'd load and fire mine up with PYM1298 (much like Kappa 12a) - might get one running as its already in place -what's your new crossover look like? my tweeters need new diaphragms.
Old 1st May 2013, 07:06 AM   #24
Simply Speakers or Crites are probably the best bets for good diaphragms.
The crossovers are still a work in progress. Listen, rudimentary measurement, tweak. I am working out component values, size, layout. The current iteration sounds quite nice, and is a major improvement over the stock crossover with the caps replaced, even with minimal burn in, so maybe getting close. (The stock crossover is still in place, so it is a simple switching of wires to compare!)
I am trying to keep the crossover pretty simple, minimalist. Every time I try to get too complicated, I don't like the results. The finished crossover will take the place of the stock crossover enclosed under the mid horn.
I think this schematic is pretty close to what I am listening to now.
Geary
Old 1st May 2013, 07:31 AM   #25
Here is an EV engineering frequency plot with three different woofers in the Sentry IVB:
Gefco, (Alnico)
EV ELM12
EV Force 12
Geary
Old 1st May 2013, 10:28 AM   #26
freddi's Avatar
(i uploaded that a long time ago -info came from Jim Long) - those are MBGO(?) - is that bass inductor nicer sounding than say a steel-core ERSE?
Old 1st May 2013, 03:49 PM   #27
I may have pinched the freq plot from you! The 30uF caps are MBGO, the 2uf caps are KBG, the 1uF are Good-All PIO. The bass coil is Solen. I don't know how it would compare to the iron core Erse. I am running such low power, (45 & 2A3 SET's), that saturation is an unlikely issue.
Geary
Old 5th May 2013, 10:00 PM   #28
I think that I am close to where I want to be with the crossover. I moved the tweeter high pass back to 4750Hz with a 3uf cap. This improved the treble presence which was a bit lacking with the tweeter crossed over at the 6750 with a 2uF cap. This is the schematic of where I am today.
I am going to play around with the 1uf cap paralleled with the 2uF caps for the mid and treble. I will then bypass the mid 30uf cap with small value film or PIO cap. (Thinking .22 or .33 uf).
Geary
Old 5th May 2013, 11:24 PM   #29
phivates is offline phivates  United States
This is cool...who needs Altec?
Old 19th May 2013, 04:43 AM   #30
Not me!!!
Geary
Restoring Electro-Voice Sentry IV-AHide this!Advertise here!
Electro Voice E-V1244 TomWaits Solid State 12 13th January 2015 01:42 AM
Vintage Electro Voice Tajzmaj Swap Meet 1 20th November 2011 08:03 PM
Electro Voice Patrician IV--for sale/trade Bill F. Swap Meet 11 22nd July 2009 01:48 AM
EV crossover datasheet SentrY III & IV sbobba Multi-Way 5 13th March 2009 09:52 PM
Electro Voice dirtyk777 Subwoofers 1 29th July 2007 11:02 AM
