Restoring Electro-Voice Sentry IV-A
Old 28th April 2013, 09:41 PM   #11
Carl_Huff is offline Carl_Huff  United States
After reading this thread I come across a pair of EV Sentry IVs advertised in the Los Angeles Craigslist. The guy only wanted $100 for the pair so I jumped on them. I've just brought them home. All of the parts are there but the cabinets need some work. They spent a year exposed to the southern California sun and definitely show the damage. Yours are clearly in much better shape.
Best Regards,
Carl Huff
Old 29th April 2013, 01:16 AM   #12
phivates is offline phivates  United States
Default RCA
My horn is done at 60 both in path length and circumference. The corner, and a bit of eq, gets it as low as it needs to go. Of course another octave down would be fun but that's where my friends surplus 2245s might fit in...the "ring of fire"
won't be going on in my low power world.
Old 29th April 2013, 02:00 AM   #13
Pano is offline Pano  United States
Pano's Avatar
Nice find, Carl. Congrats on that.
Old 29th April 2013, 05:31 AM   #14
galyons is offline galyons  United States
That's a steal! Good job! How are the drivers?
Geary
Old 29th April 2013, 05:25 PM   #15
The previous owner had bought them new back in 1978. He still had the sales receipt for $1300. He used them regularly right up until just a few years ago. When he took them out of service he removed the horn and crossover assemblies and stored them inside. The cabinets were put under a tarp in a storage shed and more recently outside up on cement blocks. At some point squirrels got inside and chewed holes in the the drivers. As result the EVM 12L drivers will all need recone kits. Those are $60 apiece. I will do the recone myself. The crossover, tweets, mid horns & CDs are all in good condition.
After getting them home I more closely examined the cabinets. They are not in as bad of a condition as I had first thought. Only the outer veneer of the plywood is damaged and only on a few panels. All corners and joints are still tight. EV used a quality plywood when they built them! I think a couple of busy weekends spent using a belt sander, poly resin & hardener along with a good industrial primer should make them look like new again.
Best Regards,
Carl Huff
Old 29th April 2013, 09:18 PM   #16
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Bondo is your friend, if your just going to psint them thst is.
Nick
Old 29th April 2013, 09:33 PM   #17
Yea, I agree. However I try to 'seal down' anything that is even marginally loose with polyester resin using a squeegee and then fill holes and depressions with a quality bondo before I paint. Rage is my current favorite 'Bondo' product: Evercoat
Best Regards,
Carl Huff
Old 1st May 2013, 04:18 AM   #18
Carl,
Need pics, squirrelly woofers and all. If your mid horns are like mine, I would suggest threaded inserts for mounting the tweeter rails rather than wood screws. I have plenty of 8-32, gladly send you some.
Geary
Old 1st May 2013, 04:23 AM   #19
Here are my before and after pics on the Gefco woofers!
Geary
Old 1st May 2013, 04:29 AM   #20
Here are the mid horn tweeter rails repair in process:
They just kept using bigger wood screws and more glue! I replaced with 8-32 threaded inserts and SS cap screws.
Roughed in repairs with 2 part epoxy putty. I used small brass wood screws to form foundation posts in the broken out structure.
Cleaned up wood screw holes in the "undamaged" horn, screwed in threaded inserts with Gorilla Glue.
Geary
Restoring Electro-Voice Sentry IV-AHide this!Advertise here!
Electro Voice E-V1244 TomWaits Solid State 12 13th January 2015 02:42 AM
Vintage Electro Voice Tajzmaj Swap Meet 1 20th November 2011 09:03 PM
Electro Voice Patrician IV--for sale/trade Bill F. Swap Meet 11 22nd July 2009 02:48 AM
EV crossover datasheet SentrY III & IV sbobba Multi-Way 5 13th March 2009 10:52 PM
Electro Voice dirtyk777 Subwoofers 1 29th July 2007 12:02 PM
