Old 29th November 2003, 02:03 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Transmission lines and 2.5 ways crossovers
Hi all,
I was wondering how to design a TL loudspeaker, with a 2.5 ways crossiver (1 tweeter, 2 midbass)
The lower midbass would be used for baflt step compensation, so it will only play low frequencies.
That's the problem! For the mids, the TL sees one driver, but for the lows it sees 2 drivers.
How should I design it? Like if it would use only one driver, like if it would use both of them all the time, or another way?
Thanks for help
Alex
Old 29th November 2003, 02:19 PM   #2
Definetely like you have both !
I'd checkout the MTM designs like the Ariel and Seas Odin
that exploit the twin units to smoothen the bass response.
And then possibly adapt a 2.5 way design for T/L loading.
Below ~ 400Hz there no difference between a 2.5 and a MTM.
/sreten.
Old 29th November 2003, 03:20 PM   #3
delwon is offline delwon  United States
Hi Bricolo,
I've built two pairs of 2.5 way TLs and I calculated the dimensions for the TL based on using two drivers. I must not have messed things up too badly because they sound pretty good. Logically, it makes sense to do your calculations based on twodrivers since the real advantage of using a TL configuration in the first place is to improve on the low end response. The first pair I built used two 6.5" drivers while the second pair used two 8" drivers.
Old 29th November 2003, 03:25 PM   #4
By the way Bricolo....
Your topic mentions crossover, but I'm not sure you have a question about crossovers for a 2.5 way. Do you have a question? I'd be glad to share what I did.
Old 29th November 2003, 04:11 PM   #5
Bricolo's Avatar
In fact, I mentionned 2.5 ways crossovers to explain that the 2 drivers aren't always used at the same time.
For a D'Appolito configuration (or any other 2 way system with multiple midbass), you won't have this problem. So I precised that my question was for 2.5 ways
That's all
Old 30th November 2003, 10:17 PM   #6
Ap is offline Ap
Ap's Avatar
In a 2.5way BOTH woofers are covering the bass freq. range so they are BOTH loaded by the TL
-design the TL for two drivers, i.e. double the area (beginning, line & end)- keep the length the same as for one driver.
Transmission lines jj Multi-Way 3 29th March 2009 09:58 PM
transmission lines grahamfocal Introductions 12 15th January 2008 07:38 AM
Transmission lines duderduderini Multi-Way 2 29th July 2007 11:56 AM
transmission lines Dave Jones Multi-Way 9 2nd August 2003 05:06 AM
Page generated in 0.08251 seconds (73.98% PHP - 26.02% MySQL) with 10 queries
