I want to use bi-pole woofers on each channel so will be buying four (probably) 15 inch 4 ohm drivers.
But which is the best way to power them? I want to use chip amps so the options seem to be: A single amp for each driver a la Linkwitz. Wiring each pair in parallel from one amp. (For an 8 ohm load) The amp options are 'basic' amp, bridged, parrallel or both. For simplicity I would prefer the one amp per driver with something like a 3886 chip but welcome any suggestions from those more experienced in these issues. At present, it looks like the drivers that I will be using have the following T/S parameters: FS 30Hz Qts 1.2 Qms 4.55 Qes 1.78 Re 3.8 ohms
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#2 |
just another
Hi Nuuk,
Just a correction. If you wire each pair in parallel you will have a 2 Ohm load not an 8 ohm load, you will have to wire them in series if you want an 8 ohm load. Regards, Tony. |
#3 |
Thanks Tony - I have been messing around with caps to make up a crossover for the last couple of days and have parallelling caps on the brain. Of course, it should be series to get 8 ohms!
#4 |
frugal-phile(tm)
Use 4 amps
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
#6 | |
frugal-phile(tm)
dave
#7 |
Thanks again Dave, time to draw up a shopping list and get the tools sorted!
#8 |
Nuuk
What are the drivers that you will finally use? Bartek |
#9 | |
HERE at CPC FS 30 Hz, Qts 1.2, and around 34UKP. They are apparently made by Monacor.
#10 | |
frugal-phile(tm)
dave
| WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) | gtforme00 | Swap Meet | 9 | 3rd June 2008 09:57 PM |
| Virtual 4 pole PSU | ackcheng | Power Supplies | 1 | 4th July 2006 01:26 PM |
| 4-pole Potentiometers available? | fluckscapacitor | Parts | 1 | 22nd November 2005 02:43 PM |
| Have TUMULT ... will Di-pole | Aural Dan | Subwoofers | 20 | 2nd October 2004 01:33 PM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Page generated in 0.10343 seconds (77.23% PHP - 22.77% MySQL) with 10 queries |
