Old 28th November 2003, 10:16 PM   #1
Default Rear woofer loading?
From another post:
"I do have some thoughts on side firing woofers. GRollins stated that side firing woofer could keep the frontal width smaller and is obviously true. The performance suffers as the proximity of the two sides increases, requiring more sophisticated defraction baffling within the enclosure (such as BMW's matrix system) to prevent rear woofer loading. This is where deeper is better."
If it's true that a woofer's performance can suffer due to it being too close to the back interior wall of the box, then what are the tolerances involved?
Anyone
Mos
Old 29th November 2003, 12:31 AM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
The woofer is loaded by the "springiness" of the air in the enclosure, not the proximity of the back wall.
The proximity of the back wall (or more generally the opposing wall) only affects the frequency of the first resonant frequency. Shorter distances mean higher frequencies, and that's a good thing in general for woofers; regardless, the waves will be greatly absorbed by damping material...
I wouldn't worry about it.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 29th November 2003, 01:50 PM   #3
Just add B&W's matrix system has nothing to do with 'diffraction'
or 'diffraction baffling', its a bracing system for the cabinet.
Deeper is better only applies to the backwave of bass/midrange units, which you cannot side mount, you can only side mount
bass units with a front mounted midrange unit.
As Ron E said, its not an issue with woofers.
8inch woofer rear loaded horns with tweeters Naudio Full Range 1 10th January 2009 09:54 AM
Mass Loading Woofer Moondog55 Subwoofers 2 18th March 2008 01:55 AM
damping the rear wave of a dipole woofer rick57 Planars & Exotics 5 20th December 2004 02:27 PM
Woofer Towers, front-ported or rear-ported? Goldenboy Multi-Way 6 15th June 2004 06:44 PM
Separation of mid/tweeter from woofer in rear speakers dc Multi-Way 4 24th September 2002 11:44 PM
Page generated in 0.07585 seconds (70.38% PHP - 29.62% MySQL) with 10 queries
