Why resistor in parallel with inductor in low pass crossover? - Page 5 - diyAudio
Old 27th April 2013, 08:43 AM   #41
system7 is offline system7  United Kingdom
system7's Avatar
Yup, you ran into the problems I was having with series crossovers. The low order (near first-order there) looks promising, but falls on its backside with treating the drivers nicely. It's one of Lynn Olson's detested "Little Girl with a Guitar" speakers, that plain distorts with complex music. Trying to equalise out the tweeter Fs and woofer resonance then leads to too much complexity.
Let's recap what a time-aligned speaker looks like:
Seems better to me to get well-behaved drivers and give them second order filters leading to a higher order acoustic response. Might as well get an easy impedance too. Then it sounds good with any amp.
There is a nice theorem by Sidney Darlington that you can simplify the resistances in a filter down to one or two: Equivalent impedance transforms - Wikipedia, the free encyclopedia. No don't spend time on it, it all gets quite deep. The story of filters giant Wilhelm Cauer, who has the elliptical filter named after him, is more accessible and shocking.
Also interesting is the pattern that appears in the complex maths of filters where you realise that all the various solutions are just placing the poles and zeroes on ellipses, circles or anything else you fancy. This, for instance is the lovely hexagonal symmetry that lurks in the 3rd. Order Butterworth filter:
It is, in fact, a phase or all-pass network that is quite doable with opamps. What it does is produce pure group delay. No surprise you find neat ratios like 3:1 then. It becomes a geometry problem in the end. Which is neat.
Best Regards from Steve in Portsmouth, UK.
Old 27th April 2013, 01:31 PM   #42
Very cool - NOW I see where all your geometry inferences were pointing! I had heard about elliptical filters and had no idea what they were. You have put this in perspective for me. Clearly a lot to learn, but it really helps to have this framework. - Thanks again
Old 29th April 2013, 07:35 PM   #43
system7's Avatar
I'm glad you enjoyed that. Not for bricklayers, eh? You either crawl round on your belly in the ditch, or fly like an eagle over the entire landscape.
I'll give you the final piece of filtering from a higher mathematical point of view. Just to look at and enjoy without frying your brain too much.
This (correct) pole/zero view of filters:
Suppose you wrap that plane around a Riemann sphere, so the origin (low frequencies) and infinity (high frequencies) just go to the South and North poles respectively, and the poles and zeroes are on the equator.
It's a 1:1 mapping that starts to look extremely elegant. In fact it's also related to the Mobius Transformation and Conformal mapping. With these tools, filters and room and cabinet properties become rather simple. It's worth remembering that a mechanical filter like a speaker driver and an electrical filter share the same overall mathematical properties, we are just combining them at this forum.
Interestingly, Cauer started as a specialist in General Relativity, which means he knew ALL this stuff.
Inductor hi pass to filter low bass dcathro Multi-Way 12 6th September 2010 09:36 PM
low-pass crossover suggestions Telstar Multi-Way 24 18th November 2008 11:34 AM
low pass crossover help casper17000 Subwoofers 4 7th April 2006 08:54 PM
Looking for an active crossover design (low pass only)? Graemedench Solid State 5 28th August 2004 12:25 PM
Copyright 1999-2017 diyAudio
