Bought a lathe so I can turn horns - Page 6 - diyAudio
Old 2nd April 2013, 03:13 AM   #51
djn is offline djn  United States
djn's Avatar
I need horns for myself first.
Old 2nd April 2013, 03:54 AM   #52
Datubie is offline Datubie  United States
Datubie's Avatar
How about turning some in stiff foam for a core and then glassing them over?
Old 2nd April 2013, 04:06 AM   #53
I love the "Turned without tailstock at any stage comment in the picture"
I bet someone felt a tad uneasy at some point.
I have turned logs, but always at least started with tailstock.
Old 2nd April 2013, 08:04 AM   #54
Originally Posted by Magura View Post
.........A horn from 400Hz to 20kHz, would be awesome though..........
That is 5 and a bit octaves.
Way outside the recommended 3octave limit.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd April 2013, 10:39 AM   #55
djn's Avatar
Then I would have to deal with fiber glass......ick!
I've got a log just waiting to go up on the lathe, but I will use the tail stock as long as I can.
I like to use the big Heil for everything over 10khz.
Old 2nd April 2013, 01:49 PM   #56
puppet is offline puppet  United States
I love old machinery and anything Oliver is first class. That lathe will last several lifetimes.
ps, get a cage on the Cresent upper/lower wheel(s).
Old 2nd April 2013, 01:52 PM   #57
Speedysteve7's Avatar
All roads will lead to 5 ways in the end
Old 2nd April 2013, 01:59 PM   #58
djn's Avatar
My daughter already called dibbs on the lathe when I pass! Yep, I found a couple very nice gages for the saw that will protect me and still let the beauty of the old iron shine through.
Old 2nd April 2013, 02:04 PM   #59
not necessarily.
A 3way horn system with 3octaves per horn results in 9octaves, or about 40Hz to 20kHz.
a 4way system with the top three all of ~2.7octaves horns and a non-horn low bass speaker can get to over 10octaves and cover the 20Hz to 20kHz bandwidth and yet stay well within the 3octave horn limitation,
If one had enough space then, a 4way horn system can get to around 11octaves.
regards Andrew T.
Old 2nd April 2013, 02:07 PM   #60
djn ... you need the cages to shroud the blades. A snapped bandsaw blade is unpredictable.
CD Lathe soongsc Everything Else 34 24th June 2013 08:48 AM
Wood Turning Lathe Question gninnam Equipment & Tools 3 26th December 2011 07:19 AM
Fun on the lathe......Waveguides THUMP LUMP Multi-Way 19 7th December 2009 02:27 AM
need info about LP lathe etcher inertial Analogue Source 12 31st January 2009 10:05 AM
MDF on a lathe? masterp2 Multi-Way 20 29th January 2004 12:30 PM
Copyright 1999-2017 diyAudio
