Bought a lathe so I can turn horns - Page 3 - diyAudio
Old 1st April 2013, 10:04 AM   #21
Good luck. I have the same grand plan. So far I have only made small 1Khz horns, I have some European Oak and some American Cherry just waiting to be glued up and turned into something larger.
Old 1st April 2013, 11:42 AM   #22
djn is online now djn  United States
djn's Avatar
If I get it set up right, I can turn a horn with a mouth opening of 84" I think it would take a week or two just to hog out the inside. But I will start with a 1khz horn as you did.
Old 1st April 2013, 11:44 AM   #23
djn's Avatar
I have been looking for a shop press to use as a glue up station. It would be a lot easier to use one shop press then handfuls of clamps.
Old 1st April 2013, 12:03 PM   #24
Originally Posted by ODougbo View Post
How are you going convert to 3-phase?
Steinmetz circuit? Steinmetzschaltung ? Wikipedia
Old 1st April 2013, 12:09 PM   #25
You definitely wouldn't make a 84" horn from solid, I was looking at compound turning, joining lots of mitred bits together, far more efficient use of wood. Or have them like staves of a barrel, requires far more complex geometry and accuracy. I need to get my ones glued up...
If you find any tips please let me know
Old 1st April 2013, 01:20 PM   #26
djn's Avatar
Wouldn't that be something to turn an 84" horn. I don't think I'd be tackling that too soon. Yes, most of the horns will have to be glue ups. I could turn them out of solid logs, but the splitting would be an issue.
A 1khz horn could be turned out of a log though. That is small enough.
Old 1st April 2013, 01:51 PM   #27
Sin Bin
Originally Posted by djn View Post
The compound slide is very heave duty for a wood lathe. This was never meant to be a metal lathe. It was used to make round parts to make molds in a foundry. With the bed extension it can turn a piece 30 inches in diameter and 64 feet long. Yep 64 FEET. I think they only made 3 of those bed extensions.
Your lathe can turn 64feet long?
Ha Ha, it's April !st again.
Old 1st April 2013, 03:34 PM   #28
djn's Avatar
This is not a joke. I don't have that bed extension but if I did, it would be this lathe.
Old 1st April 2013, 03:43 PM   #29
AndrewT is online now AndrewT  Scotland
How does one get an 84" mouth to pass through the doorway?
Or does one build the house around it/them?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st April 2013, 03:48 PM   #30
Sin Bin
A 30 inch diameter log of lightweight Basswood 64 feet long would weigh 11,000lb approx. Think about it.
CD Lathe soongsc Everything Else 34 24th June 2013 09:48 AM
Wood Turning Lathe Question gninnam Equipment & Tools 3 26th December 2011 08:19 AM
Fun on the lathe......Waveguides THUMP LUMP Multi-Way 19 7th December 2009 03:27 AM
need info about LP lathe etcher inertial Analogue Source 12 31st January 2009 11:05 AM
MDF on a lathe? masterp2 Multi-Way 20 29th January 2004 01:30 PM
Copyright 1999-2017 diyAudio
