Bought a lathe so I can turn horns - Page 12 - diyAudio
Old 8th April 2013, 08:22 PM   #111
Speakerholic
Cal Weldon's Avatar
I am interested in your lathe and the things that will come from it. I have to ask though, what kind of Hiab or whatever did you use to bring that puppy home? Sorry if I missed the details.
planet10 needs your help:
Let's help Ruth and Dave
Old 8th April 2013, 08:46 PM   #112
djn is offline djn  United States
djn's Avatar
I rented a U Haul box truck and they lifted it with one HiLo and pushed it in the truck with the other. When I got home, I backed the truck up to the garage and used an engine picker to lift one end, then used a come-along to inch it out. When the back legs where at the edge of the truck box, I lowered the held up end to the ground and picked up the end that was still in the truck. Then drove the truck away.
When I was at the industrial salvage place, I also bought an industrial four wheel dolly. So when I let the first end down, I set it on the dolly. It was easy from there.
Old 9th April 2013, 04:18 PM   #113
djn's Avatar
When I brought the band saw home, I thought the motor (because of its size and weight) was at least a 3hp motor. But it is a very old 1hp repulsion motor and just too small for a 26" saw. My brother runs a Pizza factory where they turn out thousands of frozen pizza a day. When we were at his house for Easter, I told him I needed a 3hp, 3ph motor and I knew he had to have a number of them laying around. He told me to write everything down and he would check with maintanance. He called me this morning to come over and get my motor!!!
This thing is unbelievable. It is made to be washed down at the end of every shift and totally enclosed with no fan or blower. It is built for brutal environments. When you look at this link......check out the cost new!!!!!
Products: AC Motors: IDWNM3611T: Baldor Electric Company, a leader in energy efficient electric motors, linear motors and adjustable speed drives industry
Old 26th May 2013, 08:47 AM   #114
Banned
I hope it's not off topic and someone will help me
actually I'm building a special lathe for turning horns. I use Linear Bearings and some other stuff and a pivot and a guide. I'm just in maze about the electromotor. I don't know what rpm should I use AC or DC? I want variable speed and revers function. any idea?
Old 26th May 2013, 09:10 AM   #115
barackuda's Avatar
use any 3 phase motor with frequency controller (inverter) and reverse switch.then you can select rpm as you want. its expensive though
Old 27th May 2013, 01:41 AM   #116
PB2 is offline PB2  United States
PB2's Avatar
They don't make'em like they used to!
Old 30th May 2013, 04:01 AM   #117
Greebster's Avatar
Most anti-static mats, wristbands etc typically have 1 meg Ohm resistance tied to earth ground. Lets say the motor insulation starts to breakdown due to age, under normal conditions (dry and insulated from ground via shoes/flooring type etc) most would never notice. But add a floating wire hard tied to earth and get the life zapped out of ya! Safety first with a lathe
Old 30th May 2013, 04:17 AM   #118
Greebster's Avatar
I was pondering the idea of using an R/C outrunner AC synchronous motor or build an LRK type, and controller for this purpose. I'm sure some of the motor drives used on the larger ducted fanjets would be plenty (NOT the motor A friends I wired up does 220mph+ and it aint that little (1.6m L x 1.2m WS)
How many HP are we looking for here? Don't believe the rpm range would be an issue (especially with an LRK).
Old 4th June 2013, 12:42 PM   #119
glenv6 is offline glenv6  United States
Originally Posted by djn View Post
I've built entire planes out of fiberglass. If I never see it again, it will be too soon. I think I developed a slight reaction to it which is not unusual.
I saw the jet on your website - looked promising, what happened to that project?
Great work on your turntable plinth and the marble based amps are very nice. Looking forward to seeing what you build on this monster lathe!
-Glen
Old 21st November 2013, 03:33 PM   #120
djn's Avatar
Thanks Glen. That jet project failed because we could not find a engine manuafturer to sell us just one engine for each plane. Their liability goes down to nothing(almost) when there are two engines.
I had to slow down on the lathe because of work, but I have my nights and weekends back so I'll start up again.
First things first, I am designing and building exterior and interiour duplicators for the lathe so I can whip them out by using templetes like Don did.
CD Lathe soongsc Everything Else 34 24th June 2013 08:48 AM
Wood Turning Lathe Question gninnam Equipment & Tools 3 26th December 2011 07:19 AM
Fun on the lathe......Waveguides THUMP LUMP Multi-Way 19 7th December 2009 02:27 AM
need info about LP lathe etcher inertial Analogue Source 12 31st January 2009 10:05 AM
MDF on a lathe? masterp2 Multi-Way 20 29th January 2004 12:30 PM
Copyright 1999-2017 diyAudio
