WAF Audio Najda reviews
Old 26th March 2013, 09:33 PM   #1
RickDangerous is offline RickDangerous  Mexico
Default WAF Audio Najda reviews
I stumbled upon this thread :
http://www.diyaudio.com/forums/digit...-part-2-a.html
whilst looking for an alternative to building & designing an analogue crossover for a 3 way DIY studio monitor i want to make from drivers in PMC designs (IB1S, MB2S).
If you have used the WAF Audio Najda (245 €)
WAF - Wroclaw Audio Force
then please post your review here.
Thanks to all !
Rick
Old 5th April 2013, 07:51 PM   #2
Bump
Old 6th April 2013, 04:53 AM   #3
Inductor is offline Inductor  Portugal
Inductor's Avatar
Hi Rick,
You know you can also search the forum?! If it is of any help, awesome. If you knew about the threads already, the better.
http://www.diyaudio.com/forums/multi...oy-system.html
Transmission Line Question
Looking for diy active speakers
Old 6th April 2013, 05:04 AM   #4
Originally Posted by Inductor View Post
Hi Rick,
Oh i search a lot, but i havent seen any proper reviews yet. Would be good to have some in a dedicated thread.
Old 2nd September 2016, 09:43 AM   #5
yoshisoakland is offline yoshisoakland
There is a review on youtube in French by "jipihorn". He like the board a lot and some of his criticism has been included in the board version 1.3. He performed measurements:
noise: - 120 dB after the analogue DAC section
harmonics: 2nd and 3rd harmonic -102 dB higher harmonics well below -120dB
THD: between 0.001 - 0.004% depending on frequency
jitter: +/- 5 nanosec
The values are from a youtube vidoe from "jipihorn" in French - I hope I understood correctly as my French is a bit rusty. The tester in the youtube video likes the Najda board, especially as the price is competitive. One thing I am a bit concerned about is that while the sample rate can be 96 and 192 kHz for improved DSP calculation precision, the audio bandwidth is limited to 24 kHz by an internal sample rate converter FIR (?) filter, so 96 kHz source material will be filtered to 48 kHz. This probably is not a big problem (Shannon theorem) and may even protect us from intermodulation distortion of supersonic frequencies in the power amplifier. The noise and THD seems to be very good, and while the jitter is not exceptional it is also good enough, as even the listeners heartbeat introduced larger jitter. I really like the flexible gain structure of the board and the analogue volume control! Very tempted to buy a Najda.
Old 2nd September 2016, 02:09 PM   #6
Zonneschimmel is offline Zonneschimmel  Belgium
I have one and like it very much, but have never owned similar products so can't really compare.
http://www.diyaudio.com/forums/multi...fir-4-way.html
WAF Audio Najda reviewsHide this!Advertise here!
Econowave with WAF ? fatmarley Multi-Way 33 16th October 2012 09:01 PM
Looking for WAF helping advice sherloch Full Range 13 9th November 2010 03:20 AM
WAF issues Lostcause Full Range 15 17th August 2008 03:21 PM
WAF strikes again kendt Full Range 47 3rd January 2007 07:37 PM
6moons audio reviews ash_dac The Lounge 7 22nd December 2006 07:52 AM
