Eminence Beta 10CX (ZMA/FRD)
Old 19th April 2014, 11:36 PM   #71
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Originally Posted by ivanlukic View Post
Here is the pic!
here is the page AudioVidioPhilia: Building a pair of Adire HE12.1 Speakers
and here is the 2002-2004 HE12.1 Mark II Assembly Instructions by Adire Audio:
flesh flash flush
Old 1st August 2014, 09:56 PM   #72
MartinQ is offline MartinQ  Canada
Any updates?
Old 26th September 2015, 05:54 PM   #73
dotneck335 is offline dotneck335  United States
Default Beta10CX with Radian 450B
Has anyone tried the Eminence Beta10CX with a Radian 450PB compression driver? It looks appealing on paper--the Thiele-Small parameters of the 10CX look to appear to be able to get decent response in a smallish (1.55 cu, ft.) box, and the Radian drivers are known for their low distortion.
Old 14th December 2015, 01:32 PM   #74
211hojbjerg is offline 211hojbjerg  Denmark
I run my beta10CX with Celestion CDX1-1446. it workes quite well. I'm using an autoformer for level damping of the driver.
best regards
karsten
Old 14th December 2015, 05:08 PM   #75
best regards
karsten
Interesting....where are you crossing over? Active or passive? What prompted you to choose the Celestion driver over an Eminence or Radian?
Old 15th December 2015, 11:29 AM   #76
Crossing at 2kHz, using a passive 12dB. I use a autoformer from Silvercore for level the driver.
The Celestion is low price, easy to get, nice data sheet and not titanium.
Best
Karsten
Old 15th December 2015, 02:56 PM   #77
Looks like the Celestion driver runs about $80, about the same as an Eminence PSD2013. What's not to like about titanium? The Celestion uses a 'copper clad' aluminum voice coil with a PETP diaphragm. hmmm...not heard of that before.
That autoformer seems cool, but at about $80, it's an expensive attenuator---does it really make a difference?
Old 20th January 2016, 09:40 AM   #78
kstlfido is offline kstlfido  United States
kstlfido's Avatar
FYI-
I used the 10CX + and 220Ti on my copper speakers back in 2009. Zilch offered to help choose drivers and design the crossover. We, too; noticed notches ~6 to 10khz and also found off-axis response was a little smoother.
The intended use was for sound re-enforecement. The speakers sound quite good and have performed flawlessly since then.
Zilch chimes in around here-
http://www.diyaudio.com/forums/multi...cabinet-8.html
Hope this helps!
Best- Kent
Eminence Beta 10CX (ZMA/FRD)Hide this!Advertise here!
Importing frd and zma curves LafeEric Software Tools 7 11th April 2012 12:22 AM
anyone here work up a good crossover for new Beta 10CX? freddi Multi-Way 4 9th January 2010 04:41 PM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 01:19 PM
Speaker measurement, FRD and ZMA ux226 Multi-Way 9 4th August 2006 11:52 AM
FRD & ZMA data foo Multi-Way 4 21st August 2004 10:45 PM
