Need advice : Two way with RAAL 140-15D - Page 2 - diyAudio
Old 23rd March 2013, 11:52 PM   #11
ScottG is offline ScottG  United States
Originally Posted by yoke View Post
tnx Scott but never heard of them...try google but that didn't help
(I really don't have money to play, and cant use number of different drivers...so the one I buy I will have to stick with them for a long time...there's no room for experimenting and playing with different drivers)
would like to go with something that people have heard and was thinking about audiotechnology 18H52 ?
You might try private mailing system7 about Bandor drivers:
diyAudio - View Profile: system7
perspective is everything
Old 24th March 2013, 12:08 AM   #12
Face is offline Face  United States
Face's Avatar
Originally Posted by lousymusician View Post
A couple HIGH end drivers tested, data
What's wrong with the TD10M?
Scott hit the nail on the head. Otherwise, its a fantastic mid/woofer. I'm using it teamed with SEOS12 waveguide in my HT's front end.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 24th March 2013, 05:32 AM   #13
This seems to come up every few months on some forum somewhere. Raal says you CAN cross as low as 1.6KHz, but Face is right, you really want to keep it btw 2.5-3KHz for best performance. I've played with them used anywhere from 1.5 - 4KHz. Higher is better...at least for the Raal.
Now this makes it tough to do a 2 way well. A smaller woofer is better for dispersion, but then again not so good usually for sensitivity or low end performance. You won't get smooth, hi sens AND low end extension in one driver, so you've got to make a compromise.
You want to look for something with a smooth top end and little to no break-up. Probably no larger than a 6 1/2".
Maybe the SB Satori MW165 that Zaph recently tested would be a nice choice.
Greg
Old 24th March 2013, 08:29 AM   #14
wolf_teeth's Avatar
I should clarify that that tweeter is not a RAAL with the TD10M, but actually a Beyma TPL-50 in a waveguide.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 24th March 2013, 09:45 AM   #15
yoke is offline yoke  Croatia
yoke's Avatar
Thanks everyone for advices
will read more about every driver suggested...
I do have behringer mic,but I wasn't smart enough to buy calibrated one...but for some basic measurements it will do...have work with holmi and some little time with arta
About sensitivity ;
Is it a big issue as I will go active ? Every driver will have it's own amp to drive?
Old 24th March 2013, 06:12 PM   #16
gornir is offline gornir  Sweden
gornir's Avatar
Hi
need some advice about mid woofer to use with RAAL 140-15D to make some nice two way loudspeaker.
(probably active, as I have enough amplifiers and dcx)
I have made some big 2.5 loudspeakers but never finished them as they are to big for my room
So now I need something smaller, and need advice which driver to use with RAAL.
(scan speak,dynaudio, audiotechnology,accuton...)
(don't know when I will procide with this project, but have RAAL in my closet for last 4-5 years and would like to put it in use)
Any advice is appreciated, thanks
Josip
Here are a couple of links of RAAL measurements that could help you choose suitable cross-over frequency:
RAAL 140-15D Measurements
RAAL 140-15D Ribbon Tweeter
The Satori 4 ohm mid-woofer could possibly be a good match.
SB Acoustics “Satori” MW16P-4 Measurements
/Göran
Author of the "AudioExcite Loudspeaker Design" website & Technical Consultant for HULGICHAUDIO
http://www.audioexcite.com http://www.hulgichaudio.com.au/
Old 25th March 2013, 02:19 AM   #17
LineSource's Avatar
Make them laugh.
Make them laugh.
Make them laugh.
P.S. Studiotech etc... has anyone measured a "LATEST" AES Lambda TD6M speaker ... some claims of a new surround smoothing SPL/freq are interesting.
Old 25th March 2013, 05:00 AM   #18
Not sure, I stopped following AE progress at some point during the group buy fiasco over at AVS. I like drivers that I can depend on a good supply. Sad when it's easier to import a Raal from Serbia than trust a timely delivery from the good old USA. I see now that there is another group buy, so I still don't trust the availability for drivers outside of the buy. What have you seen or heard?
Back when I initially reported what I found with the TD6, I got the usual "well it must be how you measured it" reply. No other driver in the same enclosure did what I measured with the TD6. Nothing else ever followed that fact in the discussion on the AE forum. I'm not trying to badmouth John, because I think he makes a terrific product, but running the day to day business seems to be a weak point for him. Tough business to be in as a small quantity provider.
Greg
Old 25th March 2013, 05:04 AM   #19
About sensitivity ;
With active, you can pretty much match up any sensitivity drivers you like, BUT it's always a shame to throw away free dB's, you know. Dynamically, the system will always perform better if you do not have to attenuate the tweeter too much.
Greg
Old 25th March 2013, 07:19 AM   #20
yoke's Avatar
Thanks, for advices...
so, SB Satori would be nice choice, and I think I will go that way...
will write email to Bendor as Scott sugested and see that option also...
Thanks once again, I will get back for some more advices once I buy drivers as am like newbie even as I have build one pair of loudspeakers (but newer fineshed them).
RAAL 140-15D w/ waveguide (Results) tf1216 Multi-Way 3 16th January 2013 05:20 PM
WTB Raal 140-15D Ddd_rus Swap Meet 0 10th January 2008 04:58 AM
Raal 140-15d chrismercurio Multi-Way 17 6th November 2007 05:42 PM
RAAL 140-15D Group Buy chrismercurio Group Buys 115 28th October 2007 07:04 PM
Copyright ©1999-2017 diyAudio
