Imus - 3 way build with ScanSpeak drivers (large) - Page 2 - diyAudio
Old 22nd March 2013, 11:54 AM   #11
Yes, it's an aluminium tube,I had the same resonating sound from a plastic tube ,only noticeable al very low frequency ,generated with a tone generator.I see Xavian also is using aluminium ports, so I don't know what to think, I was thinking the more rigid ,the better .
Thank you for your advice ,I will take this aspect into acount ,and will try to make some tests, before glue-ing the front baffle...
Old 25th March 2013, 07:55 AM   #12
More pics:
Old 25th March 2013, 03:42 PM   #13
jerome69's Avatar
The port placement is not ideal too, direct coupling with the woofer ?
Not really recommended.
Old 25th March 2013, 04:51 PM   #14
Thank you for your post, we can always learn things, can you please talk a little more about this...
And if there is a problem with aluminium tubes please argue, if I will hear resonances I will aply somting antiresonant like Dynamat, or change the material.
PSthe woofer will not touch the port tube phisically...)
Old 25th March 2013, 05:33 PM   #15
This speaker reminds me something
jerome is right the port best placement should be on the bottom of the speaker back/front depends on personnal preference.
like this for example:
Old 25th March 2013, 05:48 PM   #16
Ohoo,and welcome mister PandazYa!I warned you long time ago, that I'm coming.
The bottom is excluded because I have to raise them too much on spikes...But it's on the back,maybe to high? I have experiences with the same woofer and same port placement and had no problems.
Old 25th March 2013, 06:59 PM   #17
jerome69's Avatar
I can't justify this mathematically but understand when the source is too close the resonator, i call it "direct coupling", the mass of air in the rest of the box is not take into account. It is a short circuit of the rest of air in the box. Your bass reflex should not work well.
That's all, i can't explain more.
The metal tube is from Geralfino's experience, difficult to justify or argue.
The bass reflex tube is noisy at high frequency (800H-1K), it can stimulate tube frequency. You should choose it with a large diameter.
Old 25th March 2013, 07:42 PM   #18
In this case the woofers freq will be under 400hz, we'll see after measurements.
I will rethink the placement of the port if it's possible to move it far from the driver itself, the egeled back of the enclosure unfortunately raised the end of the tube
Old 14th April 2013, 02:52 PM   #19
Baffle cuts:
Old 14th April 2013, 06:29 PM   #20
Face is offline Face  United States
Face's Avatar
Where's the bracing in the woofer cabinet?
Since it's too late to add any substantial bracing, a piece of MDF from front to back with dowels top to bottom and side to side will help.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Where to get Scanspeak drivers in the US? Ephai Multi-Way 3 11th April 2012 02:25 AM
ScanSpeak ReDiscovery Tower build pski Construction Tips 1 31st July 2011 01:41 AM
Want to build Large 3 Way - Suggestions for Drivers anilva Multi-Way 25 4th February 2010 10:43 AM
Scanspeak Drivers tomat Swap Meet 23 24th September 2008 08:10 AM
Still having great trouble with my Scanspeak build dublin78 Multi-Way 12 11th February 2007 02:57 AM
Copyright 1999-2017 diyAudio
