System Pictures & Description
Old 29th April 2006, 02:02 AM   #981
Will is offline Will  Malaysia
Default Re: New speakers
Originally posted by Frankx
This is my new 4 ways creature: tw accuton c12, mid accuton c79, mw beyma 8" 8lw30, woofer eminence 15" omegapro.
C79 and beyma in closed enclosure, omegapro in aperiodic vent. The accutons in two enclosures/one box; same for the woofers. Passive crossover for accutons and beyma, active for the omegapro (behringer ultradrive).
Sound? attack, attack, attack.
Great looking speaker project, but shame on the speaker placement. They should be clear off the back wall if you want real depth reproduction ;-)
Old 29th April 2006, 10:23 AM   #982
Sclalars is offline Sclalars  Norway
Yes I know Will, but I have a creature called "wife"
Sclalars
Old 29th April 2006, 10:26 AM   #983
OOPS! This one was not for me!! Sorry!!
Sclalars
Old 29th April 2006, 12:28 PM   #984
Sclalars
She must be giving you a hard time for you to react to this post so quickly ;-)
Old 29th April 2006, 01:41 PM   #985
No, she`s a darling (;-))
Sclalars
Old 2nd May 2006, 12:04 AM   #986
Frankx is offline Frankx  Italy
Frankx's Avatar
Thank you!
About the speaker placement I have to take in consideration my wife's opinion ... this is the best I am allowed to do.
Old 2nd May 2006, 12:11 AM   #987
Frankx's Avatar
Newfinish
The vent (a scan speak flow resistor) is on the back. About the size do you mean the flow resistor size? I think that is avaiable only one size of SS flow res (130 mm).
see: http://www.tymphany.com/products_ScanSpeak.html
Old 2nd May 2006, 02:46 AM   #988
newfinish is offline newfinish  Canada
I was told that depending on the size of the woofer you had to add more.than one..since you only have one does the sound go deeper than 40hz?do you feel like it's gobbing some db's from the woofer?cause I wanted to add a woofer but was concerned about the box size.
Old 2nd May 2006, 09:10 AM   #989
Frankx's Avatar
The woofer reach the 40 Hz but don't go deeper. I have used a pro woofer with quite high Fr because I was looking for "chest pounding" and very articulate bass more than very deep bass.
With just one port I cannot hear any problem but consider that I am not used to listen at very high volume and my room is small. If you need high power output use two ports.
Old 2nd May 2006, 03:05 PM   #990
jev is offline jev  Netherlands
Default My things
Hi, some info on my system.
TT - scheu diy and VPI 12.5 with denon 103
CD - wadia 850
pre - diy 5842a with phono section cornet octal (hagerman)
amp - diy 300b
speaker - OB lowther with beyma supertweeter and Altec OB sub (with seperate sub amp)
cable - MIT speaker and silver diy interlinks
power - diy filter and XLO cables
Sounds quite good
Current projects are Pass Aleph P, diy watt puppy (jbl 2203a as sub), gainclone and would like to build big tube amp for driving watt puppy
To little time alas!!
System Pictures & DescriptionHide this!Advertise here!
