System Pictures & Description - Page 90 - diyAudio
Old 4th January 2006, 02:36 AM   #891
Bose(o) is offline Bose(o)  Canada
Default FINALLY DIGICAM!
Hey kestrel,
nice NAD CD-player (DVD?), it wold go nicely with my NAD integrated amp. Also, here is my system.
and
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 4th January 2006, 09:21 AM   #892
Byrd is offline Byrd  South Africa
Send a message via MSN to Byrd
Bose(o) How do your DIY's sound against those 501's? I remember sitting on one of those things one day at a perty - it didn't sound so good afterward
Ross Saunders
Old 4th January 2006, 11:11 AM   #893
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Default Re: FINALLY DIGICAM!
Originally posted by Bose(o)
Hey kestrel,
and
Hi, in your second photo you have some interesting speakers... is the mid/bass driver a Seas W17ppi/H571?
Apologies if you've previously described it.
Old 5th January 2006, 10:47 PM   #894
My tweeter is the 19TNF08 by Seas, the mid/bass is a Seas P17RCP08 (close simontY, the ppi looks similar) and the bass driver is the Illusion Audio LM-804. All of these and a well designed three-way, first-order cross over net an acceptably flat response down to the 40Hz. area.
The mid-high section makes use of the finest quality cardboard and the bass section uses precision cut MDF. (I love sounding "commercial"). It's a prototype for now, but I will finish it in the spring/summer.
Also, the Bose on the shelf are 141s which are working for the "single-driver comparo" for the crossover design. It's actually quite decent for a single driver, but no match for my DIYs. Like, not even close, transparency is far less though, I do like the soundstaging of the 141s.
Thanks for the comments guys!
ERTW 4 life!
Old 8th January 2006, 08:54 AM   #895
My dad and I built two pairs of DIY speaks back in 1998. I have the ones with the oak veneer (1/4" plywood), which have a Focal tweeter (TC90 or 120, don't remember) and Scan-Speak 7" (18W/8546) woofer:
The other pair (birch veneer with dark stain) have the same tweeter, but an 8" Audax woofer, which is impossible to find these days. The crossovers for both pairs were made by Madisound, where all the drivers were purchased, as well. I think the internal wiring was Nordost Flatline. These are the first and only DIY speakers I ever built. They're definitely solidly built (the large ones weight at least 40 lbs each), but as you can see there are flaws, such as the fit in the corners on the veneer. That's just cosmetics, though, so I'm not too concerned. I hope to have the time, space, and money to do some more DIY in the future, but even these two pairs will probably last me a lifetime.
Old 9th January 2006, 09:26 AM   #896
Send a message via MSN to f.bcn
My pc speakers made with mdf and ww golf paint.
Beyma 5MP60/N and T2030.
The next project a two way speakers with red Ferrari paint for a friend.
Old 10th January 2006, 02:15 AM   #897
WICKED FINISH! How did you get such a nice finish on your speakers?
If you can get a finish like that on wood how come you haven't wet sanded the Antec Sonata case? I saw my friend's Antec case (I love Antec btw) and being a Meguiar's/car guy I couldn't stand the orange peel on his case...so, I got my sandpaper, Meguiar's acoutrement and 6 hours later .
ERTW 4 life!
Old 13th January 2006, 02:32 PM   #898
Soory for my english.
sande paper for de mdf.
the work of paint is the result of my friend. he's working on a garage.
2 times good primer and after the paint with "vernis" in french.
Old 14th January 2006, 03:52 PM   #899
Speakers are 2x B&C AMX250, JBL 2446 Sanded wood horns, JBL 2402 & Fostex 825.
The system is tri-amplified. The filter uses L+C cells using Le Cleach model for cut-off frequencies.
Amps are 50W Class A for bass, SE 300B for mids & SE 2A3 for highs.
Preamp is a 6922/12B4A, Phono preamp is a tube Hiraga, LP is not finished yet...
D/A is a PCM63K + output transformers.
Cables are J.M Reynaud for mod & Ethernet Cat5 10 pairs for speakers.
Cheers.
Old 14th January 2006, 04:01 PM   #900
must of taken some time to do those boxes and horn nice work
If I may add that if you dont want to see varnish yellowing stain with a light or dark color before you varnish
Copyright 1999-2017 diyAudio
