System Pictures & Description
Old 20th April 2005, 02:42 PM   #691
dhenryp is offline dhenryp  United States
Originally posted by Jye
Hey Drew,
They was no toilet seat used on my sub....what pic are you looking at to get that impression?
Jye
The suggestion of toilet humor sent me on a search. I assume drew meant this picture. It's an optical illusion caused by camera angle.
BTW: that is a beautiful speaker and a very nice site. It's always interesting to see construction photos.
Hen Dentures Design Group
Old 21st April 2005, 03:43 AM   #692
AJinFLA is offline AJinFLA  United States
Banned
Default How to Hot Rod your Minipod
Just for laughs I posted these on another board to show an (early) attempt at evening power response and escaping "the box" - by yours truly. Enjoy
Old 21st April 2005, 03:45 AM   #693
Banned
Default Hot Rod your Minipod
..and of course, the rear
Old 21st April 2005, 03:46 AM   #694
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
AJinFLA,
Those look pretty neat..
Old 21st April 2005, 08:25 AM   #695
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: How to Hot Rod your Minipod
Those look a lot like the pod-people spinoff from B & W... how did you construct them?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st April 2005, 05:25 PM   #696
Banned
Default "Hot rodded" Minipod
Hi Dave,
I guess you didn't quite catch it from the title's of my post's. Those ARE Minipods (Blueroom) modified (Hot-rodded if you will )
with a Vifa XT-25 up front. The original tweeter is mounted at the rear in a PVC tube + Bondo. I used damping sheet around the front tweeter (rather than bondo smoothened edges) to make the tweeter removable (non-permanent). It was completely active. I actually used a Chase RLC remote preamp to vary the volume of the rear tweeter (independent of the fronts) dependent upon what type of music I was listening to. I haven't used them in years. But they will probably end up in my spare bedroom eventually.
Cheers
AJ
Old 21st April 2005, 05:49 PM   #697
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Default Re: "Hot rodded" Minipod
Hi Dave,
Any comments on the sound - before and after the mods?
Ta
Old 22nd April 2005, 12:45 AM   #698
frugal-phile(tm)
planet10's Avatar
Default Re: Re: "Hot rodded" Minipod
That would explain the similarity... i missed the title completely ... duh...
dave
Old 22nd April 2005, 12:47 AM   #699
Banned
Default Re: Re: Re: "Hot rodded" Minipod
dave
Dave ate to much chocolate this day :O )
Old 22nd April 2005, 12:48 AM   #700
Banned
Hi Simon,
I don't recall what they sounded like before the mods, since the sole purpose of buying them was for the unique cabinets. The drive units are not state of the art by any means, but are not junk either. The tweeter actually measured ruler flat (on axis), as flat if not flatter than the XT! Modified they actually sounded pretty good. I started with a D25AG35 back in '99, then changed to the XT as soon as it was available for DIY. On good recordings they would essentialy "disappear" the way a good speaker should. The XT-25 has a unique sound (if you have ever heard it) - very clear/clean, etc. There is a reason why it's used in so many designs. It's response plummets off-axis however. The rear tweeter was an attempt to even the power response, as well as add just a little "sparkle" to the high end. Placement out into the room was a must. But that forced me to use a higher XO to my sub than I would have preffered, since even though it has decent bass output, it's still a 5" driver. If you can pick up a pair in England for cheap, it might make for a fun project. Unfortunately that was my last "box". There's no going back now after these
System Pictures & DescriptionHide this!Advertise here!
