System Pictures & Description
Old 20th April 2018, 07:41 PM   #3061
Gregje is offline Gregje  United Kingdom
Great work yoke!
BTW, what is this little pvc pipe speaker in the background. I am looking for something my wife could connect her iphone to in the kitchen...
Old 20th April 2018, 08:03 PM   #3062
yoke is offline yoke  Croatia
yoke's Avatar
Originally Posted by Gregje View Post
Great work yoke!
Thanks Gregje
Those white ones are Anthony Gallo Due
thay are a little expensive but you can try ebay...thay come from time to time on ebayuk for nice price (that's how I get mine )
but you will nead an amplifier too...and a sub
Old 21st April 2018, 01:36 PM   #3063
Brettn56 is offline Brettn56  Australia
Default My current system
I made a set of towers a few years ago. Standard ported design using bass box pro. Each driver has its own sealed enclosure. The whole speaker cabinet then has a 25mm (1") mdf outer with an oak veneer finish. They look great. Drivers are 8" Jaycar response units from about 10years ago. The sub driver in the bottom is a 4ohm car audio speaker. Each cabinet has a dedicated 250watt rms amplifier just for the sub. The rxv673 has a trigger output, which I used to trigger a midget, to turn the external sub woofer amplifier modules on. The tweeter/woofer use an 18db/octave home made crossover. Amplifier at the moment is a Yamaha rxv-673, but I'm about to pull it to bits. The power output of these new amplifiers is just no where as good as the older units. One look at the transformer inside tells me it's probably good for 100w/channel at best. I'm in the process of building a set of 175w rms amplifiers to be used as the main channel for this amplifier. So I'll be removing the main audio stage, and supplying this as an output to an external amplifier. I'm doing this so I can retain the Dolby surround, and all the cool Ethernet features this amplifier offers.
All in all the sound is great. Tight bass response, very balanced sound (without the sub turned on).
Old 3rd June 2018, 05:01 PM   #3064
Vortex is offline Vortex  Hungary
Vortex's Avatar
Send a message via ICQ to Vortex System Pictures & Description
Originally Posted by sevenup2278 View Post
High power 3 way system with (12" 6.5" 1")
What kind of midbass/midrange is that ? Looks nice.
Great crossover design too.. seems to be very thoughtful, inductors nicely aligned not to disturb eachother.
IT guy with a broad taste of music: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16
Old 4th June 2018, 10:03 AM   #3065
Sclalars is offline Sclalars  Norway
Hello guys!
Here's a pic of my diy hi-fi room and diy speakers. 12 Seas 26 Lroy 10" up to 200Hz, and Seas Exotic full range in front.
I couldn't be more happy with the sound in this room
I've taken very much efford to make this room as a propher "listening room" as possible.
(Sorry for my bad English)
Back wall, with 60 cm isolation, and the floor too.
Finished back wall
Side and roof reflection traps
And of course, a diy turntable Denon DP 75 With MG1 air driven arm.
Diy turntable shelf
Old 4th June 2018, 11:01 AM   #3066
mhouston is offline mhouston  Australia
mhouston's Avatar
OMG, excellent.
Old 4th June 2018, 05:16 PM   #3067
Mike Gergen is offline Mike Gergen  United States
That is the best looking room and gear I've seen in a long time.
Old 4th June 2018, 09:30 PM   #3068
XMechanik is offline XMechanik  Poland
Sounds better than it looks. A WAF system, based on Datyon RS100-4. In the role of an assisting woofer, nice and cheap stx w15.140.8.mcx. Crossover frequency 500Hz. more
XMachina page thread
Old 4th June 2018, 10:53 PM   #3069
Dan998 is offline Dan998  United States
Default Speakers.
Originally Posted by dave123 View Post
sorry for off-topic, does anyone recognize this WWMTMWW speaker in this picture:
Speakers are the Gryphon Trident speakers.
Old 4th June 2018, 10:55 PM   #3070
yoke your speakers look amazing
System Pictures & DescriptionHide this!Advertise here!
