System Pictures & Description
Old 6th December 2017, 07:50 PM   #3001
Bergfinn is offline Bergfinn  Norway
Thank you, now l understand.
Well, its really not a bassreflex box.
It's more like a copy of a Truels Gravesen design.
Google Gravesen and cyclop, and you understand.
I also have the original cyclop midrange box with the Seas 5" driver, but deside to leave it and maybe use it for tv-sound
Old 6th December 2017, 08:13 PM   #3002
Brett is offline Brett
Brett's Avatar
^^ Ah, aperiodic. That makes more sense. Thanks, I was curious otherwise.
The GPA12's are good drivers but I'm not sure they'd be the best fit for an OB. I'd look at something more designed for the application as the GPA Q may be too low especially on a narrow baffle.
Old 6th December 2017, 09:18 PM   #3003
mhouston is offline mhouston  Australia
mhouston's Avatar
Bergfinn, looks good.
Old 7th December 2017, 02:07 PM   #3004
zmyrna is offline zmyrna  United Kingdom
CD+horn top
1x GPA 414 mid
2x 15"beta SLOB bottom
Much more compact and similar if not better performance
Sell the remaining dozen GPAs and donate the $ to charity (or donate the GPAs to poor audiophiles). Happy holidays
Old 7th December 2017, 02:22 PM   #3005
I will keep my 1212" GPA's for bass duty. Very good sound from 30-200 hz.
Double GPA 12" for 200-1khz, black JMLC400 for the TAD2001 up to 9-10k and a T500 on top.
I think that's a good plan. And of course, a different color ;p
The Jantzen 8" and Eminence 15 beta can go up to the livingroom followed by a AMT l have in stock.
Family speakers
Old 8th December 2017, 02:26 AM   #3006
suprf1y is offline suprf1y  Canada
Originally Posted by Wiggle8 View Post
I used black satin spray paint followed by a light coat of a textured "stone" style spray paint. I've been playing with the stone paints for a while and learned some lessons:
It works best to have a complete base colour already. The stone paint is basically just specks of materials. It cannot be relied on to supply coverage without really overdoing the texture. It works best, IMO, as an accent coat on an otherwise finished product.
As well, definitely do a test spray before going on a finished speaker, each can sprays a bit different and its easy to over do. It's almost best to imagine you are "throwing" the material onto the speaker, big sweeping movements with quick little bursts of the valve. Especially if you only want an accent.
After the stone paint I covered with a couple of coats of spray on polyurethane. This is important because the textured paint will collect dust and dirt easily and will not wipe clean otherwise.
Good advice. I found the black needs a pre-finish, but recently used the tan on some stands in bare pine and it was really nice on it's own. Also using Rustoleum bed liner on cabinets. Nice matte finish and light texture.
Old 8th December 2017, 08:05 PM   #3007
sewerin is offline sewerin  Russian Federation
Old 9th December 2017, 03:39 PM   #3008
NATDBERG is offline NATDBERG  United Kingdom
Impressive !
Old 9th December 2017, 04:09 PM   #3009
nuconz is offline nuconz  United States
is this a single driver speaker system?
Old 15th December 2017, 03:14 PM   #3010
baco99 is offline baco99  United States
Great thread! I have a list of speakers I rotate through, but I am using these Holt Hill Audio Cionnsaile Monitors on matching stands at the moment. Connected to a restored Bogen DB230A integrated from 1959. Source is a Pioneer DPR-609 CD Recorder that I also use as a DAC, as well as a Bluesound Node. Turntable is usually a Revox B790, but I have it out of rotation right now to fix the dust cover.
System Pictures & DescriptionHide this!Advertise here!
