System Pictures & Description
Old 16th August 2017, 05:27 PM   #2991
JustinB is offline JustinB  United States
Default Current System - To be replaced!
Most of the specs for these have been lost to PC upgrades, but this is the system that I currently listen to, and will be replacing in the near future (see my post with the design thoughts and questions I currently have?)
Center channel makes noise, but has some pretty serious design flaws. It was my 3rd build and first attempt at crossover from scratch. Drivers are spaced too far apart, forgot that the tweeter was 6 ohm in x-over design (ran for 8 ohm numbers), and the woofers are in separate chambers - one sealed, one ported. Just weird. I was able to work on box construction technique and learned how to do a Piano finish, though - good experience! Not sure what I will do with this when I build my new setup...
Towers were my 4th build. Found some 8" drivers on clearance, and spent a little bit of $ on the Seas Prestige 5.5" mid and Vifa D27SG15 tweeter . Proceeded to make weird design choices and probably butcher the x-over (cannot remember any specs). Really stepped up cabinet construction, learned veneer. Pretty good sound - the best thing I can say about them is that they are not fatiguing to listen to and they will get loud. I know I am missing detail somewhere, but at least my ears don't hurt. These are quality drivers, and I will likely re-use them in a completely re-designed tower for the 2-channel listening space my wife and I are setting up in our front sitting room.
System is driven by a Pioneer Elite SC-05 receiver (have yet to even default the unit and set up for my own space after buying used). Sony PS3 plays round things and streams. Denon DP-300F turntable with DL-110 cartridge spins vinyl. I'll end up moving the turntable into the front room for dedicated 2-channel space and the living room will end up strictly digital.
Old 6th November 2017, 03:05 PM   #2992
Wiggle8 is offline Wiggle8  Canada
Latest build is Creativesound V1 bookshelf 2-way. These are a Christmas gift for my sister. VWR-126X mid-woofer and LD22 tweeter. Base was made from pine stair tread.
Old 6th November 2017, 10:32 PM   #2993
mhouston is offline mhouston  Australia
mhouston's Avatar
The paint job looks like the Houston Finish. How did you paint them?
Old 7th November 2017, 12:09 AM   #2994
I used black satin spray paint followed by a light coat of a textured "stone" style spray paint. I've been playing with the stone paints for a while and learned some lessons:
It works best to have a complete base colour already. The stone paint is basically just specks of materials. It cannot be relied on to supply coverage without really overdoing the texture. It works best, IMO, as an accent coat on an otherwise finished product.
As well, definitely do a test spray before going on a finished speaker, each can sprays a bit different and its easy to over do. It's almost best to imagine you are "throwing" the material onto the speaker, big sweeping movements with quick little bursts of the valve. Especially if you only want an accent.
After the stone paint I covered with a couple of coats of spray on polyurethane. This is important because the textured paint will collect dust and dirt easily and will not wipe clean otherwise.
Old 7th November 2017, 09:58 AM   #2995
mhouston's Avatar
retro-thermionic: "VoXDeuX65" - 2-Way with 6.5" woofer\mid and Isodynamic ribbon tweeter
The Houston Finish I have used on all my speakers is done with a roller. The method is used on the primary coat also.
First use only a high quality paint. Go over the whole speaker box with a very wet roller just once. Do not add any more paint from this point. Now go over the box three times with the same roller adding no more paint. So what you are doing is teasing out the stipple the roller is producing. The paint is starting to thicken and dry as you go over the with the drying roller. Only go in one direction. After three dryer rolls and with the primer coat being teased the same you get a thick stippled pro, dull (though gloss paint) finish. It is sound dead and light dead. After a month it is quite tough.
Take a look at the link.
Old 17th November 2017, 03:37 PM   #2996
3wayaddict is offline 3wayaddict  Netherlands
3wayaddict's Avatar
what are they based of? Wilson Audio Alexx or Alexandria XLF
Old 6th December 2017, 06:39 PM   #2997
Bergfinn is offline Bergfinn  Norway
Fan less HTPC with JRiver and Audiolense software DSP.
8 channel RME Fireface UC USB soundcard.
Bass; 612" GPA 414 in SLOB.
Midbass; 215" Eminence beta in OB.
Midrange; Jantzen JA8008 HES in vented box.
Tweeter; TAD 2001 in Eighteensound XT1086 horn.
Still playing with crossovers, sounds ok with 150, 700, and 1400 for the moment.
This is a waiting-system, not finished. Will get a JMLC400 for the TAD, and maybe a Fostex T500 tweeter. And double GPA 12" for the midbass.
Old 6th December 2017, 06:56 PM   #2998
Brett is offline Brett
Brett's Avatar
^^ I'm not seeing the point of porting the mid when running it over an octave BW 700-1400Hz.
Old 6th December 2017, 07:23 PM   #2999
My english is bad. Can you say it in a different way, please? I dont understand.
As I wrote, this is a waiting system. More to come a bit later...
Maybe early 2018.
Old 6th December 2017, 07:36 PM   #3000
Brett's Avatar
You are running the JA8008 between 700 and 1400Hz according to your earlier post. Why port it? What advantage do you get from doing so? I personally see none.
System Pictures & DescriptionHide this!Advertise here!
