System Pictures & Description
Old 1st February 2016, 10:42 PM   #2861
mhouston is offline mhouston  Australia
mhouston's Avatar
Originally Posted by Jabbejokker View Post
Tapered quarter wave construction of my own design. Asymmetric crossover 1st/2nd order. Nice response to high thirties. Reasonably flat response.
Can't figure out how to rotate the picture sorry.
Neat, simple, looks good.
Old 4th February 2016, 01:49 PM   #2862
technofreak is offline technofreak  Estonia
technofreak's Avatar
Send a message via MSN to technofreak
My system-in-progress.
Main source is Asus Xonar DSX S/PDIF coaxial to input selector/ADC box (for an occasional analog source), to 75/110 ohm Neutrik transformer to digital input on DCX2496. Power amplifiers: t.amp TA-450 for mid-highs above 438 Hz; TA3020 based class T amp for midbass; temporarily a bridged STA540 chip for subbass. Speakers are Thomann 18-500/8-A for subbass (build thread here), Fane Sovereign 8-225 for midbass, ACR TT-50 titan dome for mids and Seas 22TAF/G for highs. Frequency response measured from listening position, 1/12 octave smoothing. Ignore roll-off above 10 kHz, my measuring mic has limitations
To-do: proper amp for the subwoofer; Scan-Speak Discovery 10" woofers in sealed cabinets for midbass; proper finish for the speakers.
Old 4th February 2016, 02:24 PM   #2863
nuconz is offline nuconz  United States
lovely. how does it sound?
Old 4th February 2016, 03:22 PM   #2864
It sounds, well, real. As in you're really listening to music, not speakers. The TT-50 has it's quirk - rise in 3rd harmonic distortion at around 4 kHz - but it's still below 1% and not really objectionable. The 22TAF/G is easily among the best dome tweeters I've ever heard; no metallic harshness usually assotiated with metal domes, and no unnatural dullness that is plagueing many soft domes. The cheap Thomann 18" driver is not the lowest or loudest and needs EQ to get flat, but, again, sounds real. Double-bass and drums sound just like that, real instruments, not some plasticky imitations of ones.
Old 4th February 2016, 04:17 PM   #2865
guangui is offline guangui  Puerto Rico
Do you thinks that the sub is large enough?
Old 4th February 2016, 04:49 PM   #2866
Can they ever be large enough? It's actually "only" ~360 liters Vb (compare that to some 500+ liter LLT-s with one 18" driver built by home cinema nuts). It's 1,5 meters wide, but depth of the cabinet is just around 40 cm. About 225...300 liters tuned to about 25 Hz is normal for real 18" cinema subs, I made mine just a bit larger and tuned lower.
Old 4th February 2016, 06:02 PM   #2867
Teradacto58 is offline Teradacto58  Canada
Teradacto58's Avatar
Default Family Room
Just finished a new plank vinyl floor....new leather sofa's are in...going out this weekend to buy a new carpet to tone the room down... put the Bronze Akai 2650 pair in the family room.....an SA find for $30/pair......running a pair of Cambridge Audio R50's + Dynaco A25's.....Running a 110watt/ch 7.1 Yammy for the surround sound...4x Celestion 25's...10" Energy sub...2x Cellestion 1's ,Klipsch center Channel + Design Acoustics rear center... The small Bose 121's were a GW find...bought them to flip....
Old 7th February 2016, 11:20 AM   #2868
Hsmeets is offline Hsmeets  Netherlands
Speakers: Closed Box, Scan-Speak Revelator and Illuminator drivers, cabinet design inspired by Marten, Kharma, etc
Electronics: MiniSharc DSP, ESS9016 based 8ch DAC, balanced interconnects to a Hypex UCD180HG based 6ch Amplifier.
Old 7th February 2016, 07:34 PM   #2869
NATDBERG is offline NATDBERG  United Kingdom
I love the design of the base of those speakers in particular! Nice and spacious..
Do you have a build thread anywhere on the internet to look at?
Old 7th February 2016, 07:50 PM   #2870
Only in Dutch. Speaker built starts around page 17 (Thread starts with a different build of mine, at page 17 this one starts)
Speaker built: forum.zelfbouwaudio.nl • Toon onderwerp - Project #2: Vloerstaander
Electronics:
forum.zelfbouwaudio.nl • Toon onderwerp - [Longterm] MiniSharc + AFDAC2 + UcD
System Pictures & DescriptionHide this!Advertise here!
