System Pictures & Description
Old 9th June 2013, 10:27 AM   #2341
Overkill Audio is offline Overkill Audio  United Kingdom
Overkill Audio's Avatar
Default 7o's style rug
Hi Sprags,
Yes the rug is cool! The guy's house was amazing and room acoustics were good, the rug really helps reduce floor bounce.
By the way, the new Daft Punk album" Random Access Memories" is GREAT!!
Enjoy!
Derek.
Old 15th June 2013, 03:05 AM   #2342
neutron7 is offline neutron7  Canada
neutron7's Avatar
not that i have anything against tarkuses, i even modeled one once.
After a long slog (i do too many projects at once)
Its a pair of tri-amped speakers. used on my front channels(and stereo of course)
i call them "manticore" because i made tarkus before and spent tons messing with the crossover. if you look on the album cover art of "tarkus", manticore kills the tarkus.
tweeter: SEAS 27TDFC with 75uf film capacitor for safety (in case i make a mistake programming)
mid/bass: SEAS ER18RNX
woofer: CSS SDX10
tweeters and mid/bass powered by emotiva upa-500
woofers powered by emotiva upa-200
miniDSP 4x10(2x8 plugin)
the cabinet front is not finished but this is about the speakers. Im using a laptop to program the DSP with, while i make some changes to (this thing) http://imgur.com/a/R5PSO
yeah the phone us usually in the kitchen but i just got a different internet connection and had to get it out of the way.
I am really happy with this. it sounds fantastic, very clear, goes down as low as i can hear very nice sound stage, and lots of audiophool adjectives! and i can make any changes i like without buying new crossover bits.
other people have asked me if the emotivas should be stacked. here they are after being on with the TV on for a few hours and then loud music for a couple of hours.
not bad at all 28.4c is the hottest thing on the picture, and i still haven't put feet on the miniDSP to get it off the vents of the top emotiva.
a cool trick, if you do something like this, and keep your old center and rear channel powered by a reciever, is to adjust the PEQ on the midrange to be wrong in a similar way to your old speakers, and use that miniDSP preset when watching things with surround. it makes the miniDSP powered speakers sound close enough to the old ones that there is no strangeness.
i have:
preset 1: music. everything full flat and REQwizzed as best possible for my room. lots of bass extention, a bit of boost below woofers resonance, which is quite hearable.
preset 2: same as above but "neighbors home" bass is reduced and no "linkwitz" boost below woofer resonance.
preset 3: all out but with midbass altered to sound more like the little polks i have for surround and center speakers
preset 4: same as above but with "neighbor home" on the bass.
as for the emotivas themselves, not bad at all! the price was good enough to get them instead of building a bunch of chip amps or whatever. they have been great so far.
Old 15th June 2013, 06:31 PM   #2343
Dan998 is offline Dan998  United States
Check out these Sonus Faber Amati Homage clone speakers.
The cabinet looks amazing.
There at the bottom of the page.
http://www.htguide.com/forum/showthr...us-Faber/page3
Old 10th July 2013, 05:12 AM   #2344
nationalkid is offline nationalkid  Japan
I made a speaker system 3-way system.
The size is width 340mm, depth 340mm, 400mm height, 35 liters of sealed. Thickness 15mm. 15Kg weight.
Speaker units is ParcAudio DCU-171PP (~ 650Hz), Onkyo HM500A-MK2 (650Hz ~ 8KHz), Technics 5HH10 (8KHz ~).
Network has modified those of Coral CX-77.
Super bass can not be played, however, sound a powerful and delicate is obtained, I am very satisfied.
Old 10th July 2013, 06:33 AM   #2345
chlorofille is offline chlorofille  Malaysia
chlorofille's Avatar
2 way MTM. Tweeter : Scanspeak D2904 7100. Bass drivers : 2X Scanspeak 21W8554. Huge effortless sound...
Old 15th July 2013, 02:05 AM   #2346
norman bates is offline norman bates  United States
norman bates's Avatar
my latest setup.
jbl 2407h on the mcm round horn
8" 4ohm silver flute woofer
dual 15" eminence magnum 15lf in 8ft3 tuned to around 30hz
crossed @2khz and 80hz
Old 15th July 2013, 02:23 AM   #2347
mhouston is offline mhouston  Australia
mhouston's Avatar
Nationalkid: looks good.
Old 15th July 2013, 02:25 AM   #2348
mhouston's Avatar
chlorofille: Dinesh what else is new? I see your MTMs. There is some speakers out recently which use TMT on the front and three tweeters at the back. Got a good review.
Old 16th July 2013, 04:53 PM   #2349
chlorofille, are those the Skanspeak Kelvar mids?
Old 17th July 2013, 11:28 AM   #2350
They are 8'' woofers but have surprising midrange clarity and quick decay. I have the 3Khz peak notched and a big inductor to start an early rolloff for baffle step compensation.
System Pictures & DescriptionHide this!Advertise here!
