#2171 |
The right channel as it looks now.
It's never too late to have an happy childhood http://www.homebuilthifi.com/project/5604 |
#2172 |
My new DIY set of loudspeakers
#2173 |
#2174 |
This is an example of failure
Can not play bass at all |
#2175 |
Damping the backloaded horn is not an easy job to do.Is important to begin with 2 steps:
-compresion chamber (careful with middle range) -begining of the rollercoaster. Also try to put some absorbing material on the bottom,inside of the mouth at corner. Begin with a few tiny pillows to hear the diferences.... It will take some time to do the job right..........
"I'm glad I can build my own mistakes." https://picasaweb.google.com/115586837612433686520 |
#2176 | |
1973 at that time, technology and know-how (even manufacturers) had not been established. (I regret having made too early) |
#2177 |
Those are cool! Do you have a build thread? What are they all and are you using an active or passive crossover?
Scott |
#2178 | |
Unfortunate, the original build thread was on dead-now webserver. Evolution lasted about 7 years and was centered on re-dimensioned Bruce Edgard's "Show Horns" (from 50Hz cutoff to 70Hz). Mids are Selenium's (HM4750SLF+D405), supertweeters are Eminence APT150's. Bass consists in 3 band-pass units (Behringer B2092A being one of them). All is active, digital, crossed @80/500/5kHz. System tuned for classical, which I'm fond of, and positioned in corners of a 35sqm dining-room, toed 45 deg., subs placed after Geddes method. Thanks for your interest. Dorin
It's never too late to have an happy childhood http://www.homebuilthifi.com/project/5604 Last edited by DorinD; 14th June 2012 at 08:15 AM. |
#2179 |
New bedroom speakers - based on the sten II's but with a different tweeter and modified crossover. 25mm MDF with a stone maple veneer.
I am very pleased with how these sound. ![]()
#2180 |
frugal-phile(tm)
Just to be pedantic, the CC of a BLH is the room it sits in. The chamber behind the driver is the Air Cavity.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
