System Pictures & Description
Old 5th March 2012, 02:03 AM   #2131
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Now that's a great idea!
Old 6th March 2012, 03:40 AM   #2132
Remlab is offline Remlab  United States
Default Active DSP
http://s1252.photobucket.com/albums/...urrent=008.jpg
Old 6th March 2012, 09:17 PM   #2133
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by beneeh View Post
Here is the recent project I've done with AM team. This time we experimented a bit with HiVi Swans drivers. The cabinet was inspired by the design of mark 21 by troels, made using mahony wood.
It is a 3 way system, using twin woofer for power efficiency to drive this speaker.
Tweeter: Vifa XT19TD00-04 3/4" Ring Radiator
Midrange: HiVi Swan M5A, 5" Alloy Cone
Woofer: 2 x HiVi Swan M6A, 7" Alloy Cone
Those are gorgeous, did you use solid mahogany all the way through or is it laminated?
Old 10th March 2012, 06:34 PM   #2134
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Remlab, I like your speakers, tell us more please. More pictures too.
planet10 needs your help:
Let's help Ruth and Dave
Old 10th March 2012, 08:08 PM   #2135
ABJensen is offline ABJensen  Denmark
Diy nano magnetic ribbon, with modified scanspeak 8". One on each side of inclusior. Groundsound dsp preamp or minidsp.
crosover 400hz LR24db. Ribbon 400-45000hz.
Old 10th March 2012, 09:01 PM   #2136
Speakerholic
Cal Weldon's Avatar
ABJ, that looks really tasteful. I see you have mounted the woofer amp to the wall, any particular reason? It kinda looks like a heater like that.
Also, that woofer looks small compared with the ribbon. How big is your room and why did you choose that size?
Not suggesting anything, just asking.
Cheers.
Old 10th March 2012, 09:27 PM   #2137
The amp one the wall is for and SW-12-16FR Servo Sub Woofer.
The only reason for the 8" woofer is we had them at hand. They play down too 35 hz. the room is 30 M2.
Old 11th March 2012, 12:04 AM   #2138
Hey Cal
Computer based system consisting of;
Computer
Squeezebox touch
Behringer DEQ, SRC, and two DCX's(One per channel).
Four subwoofer amps purchased from Jack Hidley(Internal crossovers bypassed)
Three Behringer A500's
Dayton cabs
Speaker bases(For main's) made from 10" Dayton subwoofer baffles.
Peerless XXLS's
Peerless HDS Exclusives
BG Neo 10's and 3's
BG Neo's attached with Dayton gasket putty only. No screws..
T-6 Aluminum channels covered with acoustic vinyl for dipole BG Neo's http://www.onlinemetals.com/
Pictures by remlab - Photobucket
Xover points; 75 150 450 1,800 (Constantly Evolving) Best configuration so far..
Seth
Old 11th March 2012, 12:11 AM   #2139
Speakerholic
Cal Weldon's Avatar
Gotcha, thanks.
Old 11th March 2012, 12:12 AM   #2140
Speakerholic
Cal Weldon's Avatar
Thanks Remlab too.
System Pictures & DescriptionHide this!Advertise here!
