#1911 |
FX001, the FX002 is a Nextel coated paper cone.
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen |
#1912 |
Oh yes. thanks for reminding me. What box volume did you need for the FX001? The reason I ask is that I am looking to use this woofer in about 35 liters sealed to get about 45Hz (-3db / Qtc 0.8) and mate it to a W16NX001.
...still looking for the holy grail. |
#1913 |
Sorry I can't give you an accurate answer, I went with a 3ft^3 ported enclosure tuned to 20hz.
#1914 |
Speakers:
CHR-70 monitors, 4L sealed with LCR series network (0.39mH, 2.7ohm, 680uF) for baffle step, trebel reduction and bass eq. F-3dB =75Hz (without crossover). Front is 18mm MDF sandwich of 6mm and 12mm to aproximatly get flush mounting. 2x 10" skytronic subs, uneq'ed f-3dB = 45Hz (free space). Aprox 40L each. Amps: Marantz PM151 (subs) SONY TA-AX220 with increased rail capacitance (monitors) Crossover: box ontop of amps 4th order butterworth @ 90HZ, sub signal is equalised such that flat to 20Hz excursion limited to 93dB @ 20HZ Misc: towels to stop subs rattling around ontop of each other. Foam on left hand wall to absorb early reflection. |
#1915 |
Great student(?) setup!
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#1916 |
it took me 3days to reading all the threads in the topic,some of the designs are so amazing! well i 'am from china.i like music very much,now it's my turn to show my ugly system
#1917 |
my system 3 way all the speakers are HIVI
the pre amp DIY by the jc2 design,the amp DIY pass a 30 colome the CD play is DIY either and i believe that the cables acounts in the audio system i like the sound very much can i upload the pics directhly to the forum? |
#1918 |
yeah dude, go for it
#1919 |
Paper Stone project. High efficiency high power handling low distortion design with added rear firing tweeter.
Complete description on PE forum here. new project in works. PaperStone BBMTMBB - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com Concept, crossover design and measurements were done by me. Loudspeaker cases by Mark Williams (my friend and happy owner) Roman. |
#1920 |
A lot of hard work. Great job !!!
www.diy-audio.ro |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.11491 seconds (76.15% PHP - 23.85% MySQL) with 11 queries |
