System Pictures & Description
Old 6th January 2010, 01:51 AM   #1741
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Originally Posted by navin View Post
Nice. Does the slot in ther rear mean the woofer is bass-reflex? Or is it the termination of a tapered TL?
No it's a bass reflex. I originally wanted to make a TL, but after reading peoples' opinions about it and not wanting very big speakers, I decided against this.
Yes. I use WavPack (also a lossless format) and MP3 (VBR APE LAME EAC) and I do notice a difference in sound quality. The Wavpak files are about 3 times the size of the MP3 files so they are not as portable but I consider them a good half way point between CD and MP3.
Good, I'm glad to read this. I don't want to be one of those crazy audiophiles that swears I hear a difference when there is none
Old 6th January 2010, 03:39 AM   #1742
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Oh I'd love to be one of those crazy audiophiles but no one takes me seriously anyway so who'd listen?
...still looking for the holy grail.
Old 9th January 2010, 08:33 PM   #1743
hpolkerman is offline hpolkerman  Netherlands
Default Mp3/FLAC/APE
MP3 is worse then FLAC, for the simple fact that mp3 steals away the range outside of what you can hear. IE when a sound is played loud next close in frequency range to another sound that is lower in loudness that sound will be filtered out. The ranges outside the human hearing is left out as well.
There are a few drawbacks to this: The sound is compressed, it depends on the compression on whether this is done good or bad. This is what people tend to hear in difference between mp3 (compressed) and uncompressed/lossless.
But the range outside of the human hearing is important to the sound as well; 10hz can be felt, even if it can't be heard. Harmonics in sound is another thing, the harminocs of certain sounds left out of the mp3 music is important: one other sound close to a frequency that is played louder is important to the harmonic build-up in sound and sound-nodes. The sound (sorry for the fuzziness of words in the next line) sound unnatural and can sound harsh...
So you can hear the difference, but only if you're trained and have a good sound-system... Sometimes I can hear a big difference, and sometimes I don't. Most of the time I do think it is because the filtering/converting music:
CD can be dirty, CD-player to rip with is degrading sound (error correction, even electrical influances). Then it is converted by a series of systems and filters... Even when you want to burn it, you'd be going through the whole series of unfiltering, all the way up to the quality of the burned CD and eventually your CD-player...
So to recapp; I do think it has influance (I can swear that the violins and cello's are more natural or more clearly spaced on original CD's) but most of the time it would be the converting to blame. But then again there is even a difference in the CD's you by, even if you'd buy the same, some prints of CD's are better then others (had bought two of the same by accident).
This is just my opinion, I am a bit of an audiophile if I would say so myself... So maybe I'm prejudice or even a bit crazy... Maybe I'll go and test some converting myself, It'll be a nice test for my ears and my system.
By the way, I use FLAC because I've read (yep... not tested, I know) that the decompressing the FLAC is easier and less fault-sensitive than APE... Anyone knows something about this (has proof?)
Sorry for some bad choices in words; I'm still just a Dutch-guy
Old 10th January 2010, 04:33 AM   #1744
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
i have to say, i can hear the 'loss' in lower bitrate MP3 (sub 320kb/s), so if i want a ultra clean digi copy of a cd ill just use WMP lossless or straight out WAV--takes a boatload of HDD space but worth it for that last drop of performance, and indistinguishable from the original CD
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 10th January 2010, 09:55 AM   #1745
JamesTRexx is offline JamesTRexx  Netherlands
JamesTRexx's Avatar
Default About compression
The major advantage of FLAC (besides being open source) is the decompression algorithm, it is rather simple so it uses less processing power than other audio codecs. That's why it's perfect for portable devices.
I've compared it with APE as someone stated it was superior and CPU power was indeed up when playing APE files. As for the compressed size there was little difference.
Fault sensitive is a moot point, it's all done in the digital space of computers where 0's stay 0's and 1's stay 1's.
As for myself, when I store music uncompressed I go for FLAC, when I want to save not only some diskspace, but also the quality I go for OGG Vorbis quality 10 and one special setting.
I've listened to several of the best cd's and various compressed versions and only OGG q10 showed no difference in sound (no differences in spectrum either in Audacity). The best thing; it's still only one-third the size of the original cd. :-)
There's much more to say on compression, but then it better be done in a seperate thread.
(to be on topic: my description and history of my current stereo setup is here: high end audio rant)
Old 11th January 2010, 05:35 AM   #1746
taloyd is offline taloyd  United States
Post Flac
FLAC is lossless, that's the 'l' in FLAC. Lossless means it is the EXACT SAME as the WAV data on an original CD. It IS compressed (that's the 'C') but like Zip files, is lossless compression.
This means that it contains the same amount of data a WAV, but takes less space. Approximately one third is correct.
I use FLAC for my CD collection on my system because it is digitally identical to the source CDs, but takes up less HDD space. There is no sonic compromise.
Frequency response, btw, is related to sample rate. 44.1k sampling will always extend to around 22k per Nyquist sampling theorem (which itself isn't PERFECTLY applicable to sound, but good enough).
Loss and compression are two different things. Lossy compression saves space by throwing away data using an algorithm derived from basic psychoacoustics (Haas effect (precedence), etc.). Lossless compression doesn't throw away any data and is exactly identical to the source, like Zip files.
cheers,
-Tal
Old 9th February 2010, 04:18 PM   #1747
jeeracing is offline jeeracing  Canada
I made the CJD center speaker MTM with the dayton rs150 ans Seas 27tdfc
jee.
Old 18th February 2010, 12:43 PM   #1748
efabyanos is offline efabyanos  United Kingdom
I agree, ogg is to my ears by far the best of the lossy formats.
Old 20th February 2010, 07:36 AM   #1749
wixy is offline wixy  Australia
Here's a pic of my system. Speakers are MJK open baffles.
Old 21st February 2010, 10:45 PM   #1750
JOHNNYFAMOUS is offline JOHNNYFAMOUS  Canada
JOHNNYFAMOUS's Avatar
My contribution,
just finishing off the sub,, need to install the grills.
ebony and figured maple.
vifa drivers.
System Pictures & DescriptionHide this!Advertise here!
