System Pictures & Description - Page 168 - diyAudio
Old 28th September 2009, 07:36 AM   #1671
Originally Posted by Juggy View Post
All:
Here are some photos of my system.
2-way bass reflex enclosure.
Vifa PL series 7" woofer
Peerless HDS Tweeter
External crossovers 24db/oct centered at 2.2 khz.
Subwoofer - 12" Peerless Woofer on 360 watt BASH amplifier.
How did you make the curve on the front baffle?
Old 28th September 2009, 10:01 AM   #1672
felixx is offline felixx  Romania
felixx's Avatar
Juggy
Nice.
How did you make the front "1/2 waveguide" on the baffle?...for drivers?
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
Old 28th September 2009, 10:43 AM   #1673
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
Originally Posted by 56oval View Post
Here's a mock up of the striplam ply & alloy baffle
Cheers
This is looking fantastic!
Juggy, great looking system too
Old 28th September 2009, 11:06 AM   #1674
56oval is offline 56oval  Australia
All:
They look better than bought one's .
Cheers
Old 28th September 2009, 11:08 AM   #1675
Here's the baffle for the 15" PHL 5021 driver
Cheer's
Old 28th September 2009, 12:26 PM   #1676
Juggy is offline Juggy  Canada
The curve was made by first making a 10 degree cut using a table saw on either side of the front baffle lengthwise. This took care of most of the material that had to be removided, then i used a belt sander to curve the front baffle and ensured consistency using a template cut at a 36" radius.
Thank you for the compliments.
Old 28th September 2009, 03:08 PM   #1677
WOW!
And How long did it take for each baffle?
And how thick is the box?
Old 28th September 2009, 03:27 PM   #1678
WOW!
It took me about 4-6 hrs a baffle (pefecting), i went from the belt sander, to a palm sander, to hand sanding. Because the speakers were going to be clear coated, any variation in angle was going to be quite visible.
The box is 1.5" on all sides, with internal bracing and damping.
Old 29th September 2009, 05:20 AM   #1679
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Here's the striplam section's for a 4 way I'm putting together .
Cheers
Cheers
Details. What drivers are you using?
The wood work is fantastic. High gloss polish is so reveling of any errors yet you dared to use it. Fantastic work.
...still looking for the holy grail.
Old 29th September 2009, 10:42 AM   #1680
Hi navin
The drivers
Raven R1
PHL1120 6.5" mid
PHL3020 10" lower mid/upper bass
PHL5021 15" bass driver
It will be an active ystem driven by SET amps I'm building .
Cheers
Copyright 1999-2017 diyAudio
