System Pictures & Description
Old 13th July 2009, 10:09 PM   #1611
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
I want that machine tool for Xmas!!!
Charming speakers indeed.
M
Old 14th July 2009, 01:13 AM   #1612
TerryO is offline TerryO  United States
TerryO's Avatar
M
Max,
I haven't seen any posts from you in a while, is everything OK?
As for the tools, I'll take any duplicates that Santa leaves you by mistake.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 14th July 2009, 01:26 AM   #1613
ikymagoo is offline ikymagoo  United States
Default wow
wow nice DIY!!!!!
Old 19th July 2009, 12:54 PM   #1614
maxlorenz's Avatar
Dear TerryO,
Max, I haven't seen any posts from you in a while, is everything OK?
It is very kind of you.
Everything is very OK.
The pandemia led me little energy to DIY...
Appart a little secret project that takes the rest of my spare time
I'll share if it goes OK.
Best wishes,
M
Old 1st August 2009, 01:12 PM   #1615
cnclld is offline cnclld  Finland
Here's my build: All-Seas 3-way construction using CD22RN4X for bass, CA18RLY for mids and the DXT tweeter. The mid is mounted in an acoustic resistance enclosure for cardioid radiation pattern. Crossover frequencies are 130 Hz LR24 and 2000 Hz LR12. The basses have their own amplifiers so the speaker is half-active.
Old 1st August 2009, 02:18 PM   #1616
tc-60guy is offline tc-60guy  United States
tc-60guy's Avatar
Greetings LIFU, Nice! What kind of upper mid are you using?
Old 1st August 2009, 06:36 PM   #1617
DorinD is offline DorinD  Romania
DorinD's Avatar
Originally posted by cnclld
... The mid is mounted in an acoustic resistance enclosure for cardioid radiation pattern...
Very interesting, can you elaborate a little more? Thank you!
Old 1st August 2009, 07:17 PM   #1618
The idea is to use the driver's back wave and attenuate and delay it to get the desired radiation pattern. This is done by the acoustical resistance in the ports on the sides on the speaker. The ports are damped with felt on the insides and their area is about 1*Sd. The enclosure is about 10 liters which I'm told might be a little large. I still get about 15 dB back attenuation trough the mid's operation range with this.
Technically this is the same as variovents and such. The only differences are in the ratios of acoustical component values. More theory can be found in the AES paper 4979 by Juha Backman: Theory of Acoustical Resistance Enclosures.
Acoustical resistance enclosures for polar pattern control is also used in commercial speakers by Amphion and Gradient in their largest floor standers.
Old 1st August 2009, 07:43 PM   #1619
ScottG is offline ScottG  United States
It's a more precise positioning of aperiodic "vents" to achieve the radiation pattern you want.
Aperiodic venting was first used to *decrease* enclosure volume
The best performance however is with large enclosure volumes where most of the system compliance relies on the driver and not the pressure from the enclosure. (..you can over-do this however if the system Qtc is much below .5. - where it becomes over-damped sounding depending on the pairing amplifier.) It's then further enhanced by adding mechanical resistance to the in box resonance (fb) of the driver - achieving: more linear mass controlled operation at and near resonance, decreasing phase departure and group delay, and decreasing impedance (..moving it closer to the driver's average). The disadvantage is an even more declining freq. response near and below fb when compared to a sealed system.
perspective is everything
Old 1st August 2009, 08:10 PM   #1620
There's more to it than vent positioning. The vent area, positioning, enclosure size and the amount of resistance in the ports all have their effect on the radiation pattern. In short, directional enclosures must be smaller and have less resistive ports than low-frequency enclosures to have enough output from the ports across the whole frequency range to control directivity.
I recommend the AES paper by Backman I referred to earlier. It is an interesting read.
System Pictures & DescriptionHide this!Advertise here!
